Thread: Temperature sensor
  1. Temperature sensor
    Sep 2019
    Edinburgh
    Hi there just got a 1.9 TDS 130 estate, usual problems, key unlocks drivers door manually,locks all but that’s it, I know there is a multitude of posts about ccm, my immediate issue is no temp guage at all, so assuming it’s the sender unit. Have had cover off engine,and can’t see it... can anyone point me in the right direction! Appreciated Adam
  2. Re: Temperature sensor
    Jul 2019
    Quote Originally Posted by madad777 View Post
    Its the sender unit. I changed it recently on my 2.5 TDi, costs about 7 euros, should be about the same price for 1.9. On the 2.5 is on the top of the engine, easy for DIY, don't know where its located on 1.9.
    It was 2 in 1 sender unit. One wire goes to the instrument cluster so you can see the temperature yourself, the other in the ecu to help control the fuel quantity.
  3. Re: Temperature sensor
    Sep 2019
    Edinburgh
    Thank you..I think it’s at the rear of the engine but maybe someone can confirm, it’s the awx engine.. appreciate the reply 😊
  4. Re: Temperature sensor
    Sep 2019
    Edinburgh
    So have changed the temperature sensor, still nothing,plenty heat coming out so not thermostat. I guess it’s a wire or the guage.. is there a fuse for it? Grasping at straws now...
  5. Re: Temperature sensor
    Jan 2017
    Dublin
    Did you change both the thermostat and the temp sensor?
    Temp sensor is at back of block above the cat
  6. Re: Temperature sensor
    1840 Post(s)
    If you have changed the sensor in the plastic housing on the back of the head you now need suitable diagnostic equipment to view the live data at the instruments and the engine ECU.
  1. Question Exhaust Gas Temperature Sensor Bank 1 Sensor 1 fault -> more noise?
    By tomas_v in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 22-02-2018, 12:32 AM
  2. Temperature Sensor
    By mikegbingham in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-10-2010, 08:32 PM
  3. Outside Temperature sensor
    By 4 circle in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 24-07-2010, 03:34 PM
  4. temperature sensor
    By waynetdi130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-04-2008, 05:57 PM
  5. Temperature sensor
    By earnshaw in forum Golf MK3 - 1993 - 1999
    Last Post: 23-10-2007, 06:49 PM
