Thread: Bre torsion value
Results 1 to 8 of 8
  1. Bre torsion value
    Feb 2017
    Rochester
    Hi guys
    So my car has been running badly since I had the cam belt changed. So today I found the torsion value on obdeleven. Now from what I’ve read the torsion value should be 0 but I’m getting this
    Now I’m assuming that -2.94 would cause wobble and vibration at idle. Would you suggest I get it changed to 0?
    Does anybody know if this is a job where you have to take everything off as if you were going to change the cam belt or can it be done by just removing the cam belt cover?
    What kind price am I looking at?
    Thank you very much for any information.
    Rob
  2. Re: Bre torsion value
    1840 Post(s)
    Yes, circa -3 degrees is too much, it needs resetting.
  3. Re: Bre torsion value
    Feb 2017
    Rochester
    Ok would that explain the wobble/vibration at idle and through the Rev range? Do I need to reset anything else with that?
  4. Re: Bre torsion value
    Feb 2017
    Rochester
    Will value 3 change when the timing is changed?
  5. Re: Bre torsion value
    1840 Post(s)
    No, value 4, from memory value 3 is injection duration, Kw stands for Kurbelwelle Grad or crankshaft angle.
  6. Re: Bre torsion value
    Feb 2017
    Rochester
    Anybody else had this issue and did you manage to change it yourself? Would I need to lock the timing before I changed the rotation?
  7. Re: Bre torsion value
    1840 Post(s)
    It would make sense, when you have been doing it for years to perfect the set up of the belt you have just done you get to know how to do it without but for a first time, take your time.... plate and peg it.
  8. Re: Bre torsion value
    Apr 2022
    Sheffield
    Quote Originally Posted by robcts View Post
    Hi did you ever sort it got same problem thanks
  1. Torsion value
    By Ste81 in forum Golf MK5 - 2004 - 2009
    Last Post: 17-10-2017, 01:30 PM
  2. Please Help Camshaft torsion value
    By WinDrop in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-01-2016, 02:19 PM
  3. Torsion Value
    By matrixpt in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-04-2014, 01:11 PM
  4. torsion value of 6???
    By ejs1995 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 15-02-2014, 07:01 PM
  5. Torsion Value on A4
    By Nigel F in forum VCDS - Help Requests
    Last Post: 28-08-2009, 09:40 PM
