Thread: Breaks going on by themselves
  1. Question Breaks going on by themselves
    Mar 2019
    Hi Guys,
    Can anyone help...
    A8 4.2 TDI Reg Jan 2008
    This was not the case when you go down hill and the breaks gently apply to keep the car to it's set cruise control speed.
    Whilst travelling at about 50 a warning light came on and soon after I notice some slight resistance to forward travel.
    A few seconds later I notice a thin wisp of smoke !
    So I came off the throttle completely and noticed the car slowed up as though I was putting gentle pressure on the brakes.
    I immediately pulled off the dual carriageway and came to a stop within a few seconds.
    I shut everything down and got out for a visual inspection.
    This showed both front discs glowing red hot.
    The brakes hadn't come on hard but might have been on too gently to notice for a while.
    I let everything cool off and called a flatbed to recover me.
    A couple of hours later they turned up and I started the car up to align it for loading.
    The brakes were not locked on but now spongy - I figured the excessive heat would have boiled off the brake fluid.
    My mechanic has looked at it and said all four brakes had been on, not just the front two.
    The rear disks weren't so hot when I'd stopped but most braking force goes through the front brakes.
    My mechanic says the master cylinder and servo have destroyed themselves but has no idea what might have caused this to occur.
    Please can anyone let me know what might have happened here ?
    Ideally if anyone has experienced the same failure, please can you point me towards the probable cause...
    Many thanks
    Mark
  2. Re: Breaks going on by themselves
    108 Post(s)
    1816 Post(s)
    Start by posting a full scan using # [code] function
  3. Re: Breaks going on by themselves
    Mar 2019
    Thanks Crasher,
    Whilst your contribution was very entertaining, unfortunately it doesn't score very highly on the being-helpful scale....
  4. Re: Breaks going on by themselves
    Feb 2016
    Blaydon, North east England
    53 Post(s)
    Quote Originally Posted by Mark_Putney View Post
    Thanks Crasher,
    You need your car hooked up to VCDS or similar and scan for fault codes. If your using VCDS you can post the full scan on this forum, it could help find the solution to your problem. Chances are you have a control unit or sensor gone wrong, a scan will help locate this and resolve the issue before you start throwing parts and ££££ at the car.
    2015 A6 Allroad 3.0TDi 218 CRTE - NEW
    2012 A6 Avant 3.0TDi Multitronic - OLD
  5. Re: Breaks going on by themselves
    Mar 2019
    Quote Originally Posted by KevTrem View Post
    I suspect these haven't been cleared down for a few years....
    Codes appearing are :-
    ECP
    P161A Glow plug
    P1653 DTCABSCM <- not too sure what this one is...
    Brakes
    01435 Brake Pressure <- I suspect this came as a result to the failure not the cause
    Kessy
    00955 Both keys <- maybe they need new button batteries
    00956
    AC
    01857 left central vent sensor
    Central Elec
    02510 Steering Col Adj
    Engine Control Mod 2
    P1573 Left Electro-hydraulic engine mount
    P161 No 3
    P161B No 8
    P161E No 5 glow plugs
    Parking Brake
    01316 Brake Control module <- this is my prime suspect, what do you think ?
    02596 Rear Brake linings worn
  6. Re: Breaks going on by themselves
    Jun 2006
    UK, Mids
    Check the brake fluid is not overfilled. If it is it can cause the brakes to drag on as it expands and has nowhere to go.
    I would clear the codes and see what comes back. Only the Brake pressure one seems relevant. Doesn't you scanner have date/times/ freeze frame? This would help filter out historical codes.
    Can you remember which warning light came on? Any messages in the DIS?
    Audi A8 - 2015 - 3.0TDI
  1. Question a4 breaks
    By olly333333 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-05-2011, 08:55 PM
  2. breaks going weak
    By Akymac10 in forum Golf MK4 - 1999 - 2004
    Last Post: 26-09-2009, 03:26 PM
  3. breaks?
    By tdigolf in forum Golf MK4 - 1999 - 2004
    Last Post: 03-03-2009, 05:15 PM
  4. Please Help A6 Breaks locked on !!
    By Jaybee31 in forum Chat - Anything with wheels
    Last Post: 26-01-2009, 12:38 PM
  5. breaks
    By garying3980 in forum Passat - Archive Topics
    Last Post: 10-02-2007, 06:15 PM
