Thread: Lights on buzzer
  1. Lights on buzzer
    Jun 2019
    lights on buzzer not working any idea how to fix
  2. Re: Lights on buzzer
    Sep 2008
    Is the 'drivers door open' graphic on the dashboard working? If not then possibly the microswitch in the driver's door lock has stopped working. This happened to mine, so rather than strip the whole door down, I used a dremel to cut a flap in the 'hidden' part of the door skin adjacent to the microswitch. As I recall, l couldn't remove the switch to check it out without breaking the mounting so I thought I'd try switch cleaner/wd40 and tapping it with a screwdriver! Obviously got lucky, because it's worked ever since. I pushed the metal flap back and covered it with duct tape. No guarantee this will fix it of course, but if you have a dremel or equivalent it's quick and might be worth a try initially. Otherwise might be problems elsewhere in the wiring or central convenience module? Maybe someone else can advise on that. Hope this helps.
  3. Re: Lights on buzzer
    Jun 2019
    Thanks for reply no graphic on dash showing door open
  1. Central locking, door lights & lights on buzzer/warning
    By lennylegs in forum Golf MK4 - 1999 - 2004
    Last Post: 25-12-2016, 10:05 AM
  2. Lights 'on' buzzer
    By Izalman in forum Polo - Derby - Lupo - Fox
    Last Post: 01-04-2011, 07:05 PM
  3. Lights buzzer
    By muddy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-11-2010, 06:29 PM
  4. lights on no buzzer
    By tom tom in forum Polo - Derby - Lupo - Fox
    Last Post: 15-10-2010, 07:11 PM
  5. Lights on buzzer?
    By darthweasel in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-04-2010, 12:37 PM
