Thread: Coolant loss & juddering
  1. Question Coolant loss & juddering
    Jun 2011
    Warwickshire
    At the beginning of the week I had the coolant warning light come on my Audi A3 2.0 FSI (2004), the bottle was pretty much empty so I topped it back up and when I drove to work the next day the light came on again.
    Topped it up again and the coolant light flashed on after driving for about a minute. Pulled into a carpark and popped the bonnet. The remaining coolant in the reservoir was bubbling and some was spluttering from the return pipe.
    I thought the return pipe was at fault so I taped it up and refilled the coolant. Got to work fine but on the way home last night the light came on. I stopped at a Tesco and was only about 2 miles from home so thought it would be fine to drive. I came off a roundabout onto a high speed road and when I put it in 4th the car started to judder badly and the engine light flashed up so I dropped it to 3rd and the juddering was lighter. Got to another roundabout so dropped to 2nd and it struggled going up a small incline. I left it in 2nd and went easy on the throttle to get it home. Luckily I only had to coast the rest of the way.
    I've topped the coolant up and left the car at home, I thought it was worth seeing if it leaks without pressure.
    Just wondered if the juddering could be caused by the car overheating without coolant? or could it be 2 different issues? I thought maybe the coil packs need replacing?
    Any advice or thoughts would be much appreciated.
  2. Re: Coolant loss & juddering
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    You could have very likely cooked your engine. No water in reservoir for a reason, and having to top it up so often is a clue. Needs looking into before you decide to continue driving it.
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: Coolant loss & juddering
    Jun 2011
    Warwickshire
    Thought it was worth adding an update for anyone with a similar issue. I fixed the problem by putting in a new reservoir bottle and changing the ignition coils. Running smooth again.
  1. juddering ,loss of power
    By ghostrider1234 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-04-2010, 05:11 PM
  2. Question PLEASE HELP..is juddering and loss of power due to a recall on the ECU..?
    By aogriffith in forum Golf MK5 - 2004 - 2009
    Last Post: 10-03-2010, 11:03 AM
  3. Golf 150 tdi juddering and loss of power
    By mk4tat in forum Golf MK4 - 1999 - 2004
    Last Post: 01-02-2010, 07:46 PM
  4. VR6 Juddering, loss of power :(
    By Miss-VW in forum Golf MK3 - 1993 - 1999
    Last Post: 04-03-2009, 01:00 PM
  5. Loss of power and juddering
    By shaiboy_uk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-07-2007, 07:26 AM
