Thread: More bush queries.
  1. More bush queries.
    Feb 2019
    Bexhill, England
    I have the A4 Avant B6 Estate 2.4 petrol Auto.
    I got a few 'advisories' on a recent MOT and I'm wondering whether they are within my sphere of amateurishness to fix at home. I have a flat and level concrete pad on which I park the car in the garden but it is not a great deal bigger than the car.
    Advisories:-
    Anti-roll bar linkage pin or bush worn but not resulting in excessive movement.
    Suspension arm ball joint has slight play Nearside Front Upper.
    I believe that these problems are causing the clunking problem going roung sharp corners/roundabouts. I also believe that there is a clunk on both front sides (whichever is under load at the time).
    I have spanners and a socket set and, so far, I know that I would also need to get some jack stands and a torque wrench.
    Is this a job for a financially challenged home-would-be mechanic? My concern is that I might get to a point where the vehicle is imobilised and then I get stuck.
    Any advice would be gratefully received.
  2. Re: More bush queries.
    scotland
    39 Post(s)
    The pinch bolt will be your biggest concern. Would advise having a garage remove them but do the rest yourself.
    The pinch bolts will either need heat or air hammer, they are notorious for being a pain.
    Sent from my ANE-LX1 using Tapatalk
  1. Question which bush is this + Oil seal?
    By George Mitchell in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-12-2012, 11:15 AM
  2. Please Help Console arm bush
    By Darektarantula in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-07-2011, 11:13 AM
  3. New car queries
    By monty51502009 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 28-09-2009, 04:44 PM
  4. ARB bush replacement -a tip!
    By Tractorman in forum Golf MK4 - 1999 - 2004
    Last Post: 21-08-2009, 12:33 PM
  5. MK4 GTI 1.8T CAI queries
    By wezzzor in forum Golf MK4 - 1999 - 2004
    Last Post: 23-12-2007, 02:08 AM
