Thread: Help please IAT issue cayc engine
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. Re: Help please IAT issue cayc engine
    1836 Post(s)
    Other than hands on, no I can’t go any further.
  2. Re: Help please IAT issue cayc engine
    Dec 2016
    Manchester
    Ok thanks
  3. Re: Help please IAT issue cayc engine
    Dec 2016
    manchester
    Sorry @Crasher just want to double check on the sensor it is the black wire which is the earth ??
  4. Re: Help please IAT issue cayc engine
    1836 Post(s)
    From memory no, black would be ignition live BUT that is not concrete, I would need to check the book of words.
    1 1 0
  5. Re: Help please IAT issue cayc engine
    Dec 2016
    Manchester
  6. Re: Help please IAT issue cayc engine
    Dec 2016
    Manchester
    @Crasher is they any change you can find out which is the earth wire on the sensor please
  7. Re: Help please IAT issue cayc engine
    #17
    1836 Post(s)
    There is no black wire according to the wiring diagram on ELSA. Pin 1 is the G42 earth and is the same one as goes to the DPF pressure sensor, it is a brown wire. The G42 output is yellow and this goes to the ECU via a 4 pin socket/plug known as T4bf but helpfully the diagram does not say where this is, from memory it is on a bracket on the gearbox below the starter motor. The other two wires violet at pin 4 and grey/black at pin 3 are for the pressure sensor G31. From the symptom, experience and the diagram, I would be surprised if the problem was not in that four pin plug.
    1 1 0
  8. Re: Help please IAT issue cayc engine
    #18
    Dec 2016
    Manchester
    Ok thanks so I’ll check if there’s any breaks at the plug end.
  9. Re: Help please IAT issue cayc engine
    #19
    Dec 2016
    Manchester
    Thanks to @Crasher I’ve found the fault and now been repaired thank you again crasher
  1. Question 1.6tdi CAYC Engine
    By djah in forum Golf MK6 - 2009 - 2013
    Last Post: 11-07-2019, 05:20 PM
  2. CAYC 1.6 tdi diesel engine. Unresolved EGR problem.
    By nickbell1uk in forum Golf MK6 - 2009 - 2013
    Last Post: 10-10-2017, 04:55 PM
  3. vw golf mk6 1.6 tdi cayc engine P0402 FAULT CODE
    By jumpjetguy in forum Golf MK6 - 2009 - 2013
    Last Post: 19-02-2017, 05:26 PM
  4. Golf 1.6 Bluemotion CAYC Engine EGR Replacement guide
    By dave254 in forum Golf MK6 - 2009 - 2013
    Last Post: 23-11-2015, 05:06 PM
  5. 05 2.0tdi Idle issue & '97 1.8 engine issue
    By dbbear in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-08-2009, 02:11 PM
