Thread: Error P0672
  1. Error P0672
    Aug 2019
    Caerphilly
    Hi gang,
    randomly had the EML pop up on the Audi A3 the other day,
    I did a quick scan with a generic OBD scanner and the carista tool and brought up the error P0672.
    No other error faults.
    As I read up is it as simple as the Glowplug needs replacing, car runs as it should, no loss of power, oil issues etc.
    I did run VCDS, only bought up 2 faults, one I think could be due to my lighting and the glow plug issue.
    Whats the best glowplugs to buy as i prob change the lot.
    I cant afford OEM as a full set it £155, ECP with discount are doing BOSCH for £55 or NGK for £81
    **How many glow plugs does this model need?
    Code:
    Address 01: Engine (J623-CRLB) Labels:. 04L-907-309-V1.clb
    Part No SW: 04L 906 021 AS HW: 04L 907 309 A
    Component: R4 2,0L EDC H22 8133
    Revision: 81H22---
    Coding: 02190012032501082000
    Shop #: WSC 06314 790 00021
    ASAM Dataset: EV_ECM20TDI01104L906021AS 002009
    ROD: EV_ECM20TDI01104L906021AS_002.rod
    VCID: 76E43D9AC95C7DFFB3-8022
    1 Fault Found
    4985 - Cylinder 2 Glow Plug Circuit (Q11)
    P0672 00 [237] - Electrical Fault
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 105176 km
    Date: 2019.08.20
    Time: 11:56:16
    Engine speed: 875.00 /min
    Normed load value: 36.5 %
    Vehicle speed: 0 km/h
    Coolant temperature: 24 °C
    Intake air temperature: 23 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 14.640 V
    TNF 167462: Write only channel
    Readiness: 1 1 0 0 0
    Code:
    Address 19: CAN Gateway (J533) Labels:. 5Q0-907-530-V1.clb
    Part No SW: 5Q0 907 530 AB HW: 5Q0 907 530 E
    Component: GW MQB Mid 127 1204
    Revision: -------- Serial number: 0003366166
    Coding: 030100041F0876005B000248080B0000000101000000000000 0000000000
    ASAM Dataset: EV_GatewLera 011020
    ROD: N/A
    VCID: 71EE0E86A0325AC766-8024
    Subsystem 2 - Part No SW: 8U0 951 528 HW: 8U0 951 528
    Component: E221 - MFL H02 0014
    Serial number: 10 04 2015 B0034639
    Subsystem 3 - Part No SW: 5Q0 915 181 H HW: 5Q0 915 181 H
    Component: J367-BDMConti H02 1011
    Serial number: 74185703001504091069
    No ASAM data for: "EV_GatewLera" (AU37)
    1 Fault Found
    8531970 - ROD - Unknown Error Code
    - 00 [008]
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 80
    Mileage: 105239 km
    Date: 2019.08.21
    Time: 22:32:53
  2. Re: Error P0672
    Apr 2012
    Aylesbury, Bucks
    I would assume 4 glow plugs, one per cylinder? And either of the aftermarket ones will be fine.
    2018 (2017MY) S3 2.0TFSI Sportback Quattro S-Tronic in Nano Grey Metallic.
    Black Edition, Reversing camera, Parking System Plus, Hill Hold, Super Sports seats, heated, Dipping exterior mirrors, B&O, Advanced Key, Magnetic Ride, Red Calipers, 19x8J 5-V-Spoke wheels in matte titanium.
  1. Replies: 0
    Last Post: 09-09-2012, 10:42 PM
  2. Replies: 0
    Last Post: 09-07-2009, 03:35 PM
  3. Replies: 0
    Last Post: 09-07-2009, 03:03 PM
  4. S3 Haldex error 65535 internal control module memory error?
    By merlin2002 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 16-06-2009, 09:08 AM
  5. Please Help CD error
    By Coxy916 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-09-2008, 01:02 AM
