Thread: ABS Pumps Interchangeable
  1. ABS Pumps Interchangeable
    Jul 2006
    Hi all,
    I've got ABS, ESP lights on and handbrake light flashing, which has been code read to be the ABS pump. There are loads on ebay, but i noticed that the part numbers all seem different, so I just pulled my battery to have a look started to wipe the thing which was caked with crud to find the number. Having found where it was, I then stupidly put some petrol on a rag and cleaned it which removed the bleedin' number as well. All I can make out of it is the last bit which is 517 BD with DE underneath. There are quite a few with 517 at the end, but no BD.
    How interchangeable are they please.
    Steve
  2. Re: ABS Pumps Interchangeable
    Oct 2017
    London
    12 Post(s)
    There will be two part numbers on your ABS pump. One for the pump and one for the module. Its always best to match the part numbers exactly although if you can find an uprated pump that VW have released to replace the same number on yours, then it should be fine. Although the part may be out by just a single letter or number it could be critical in it working or not, likely not.
    For example one I changed recently was module 1K0907379AN and pump 1K0614517BJ
    The old one was 1K0907379AD with same pump number as the old one but I only used the AN because I was sure it was an uprated replaced for the AD
    If you do this remember to save your ABS long coding.
  3. Re: ABS Pumps Interchangeable
    1837 Post(s)
    Which fault code do you have, for the G201 pressure sensor?
    Remember, just changing the part is only one part of the battle, getting the air out of the pump is another matter.
  4. Re: ABS Pumps Interchangeable
    Oct 2017
    London
    12 Post(s)
    Im pretty sure the G201 fault doesnt give the handbrake light as a warning. Probably the 1130 fault.
  5. Re: ABS Pumps Interchangeable
    1837 Post(s)
    No it just gives an ESP and ABS warning, where was the code 01130 ABS Operation: Implausible signal mentioned?
  6. Re: ABS Pumps Interchangeable
    Oct 2017
    London
    12 Post(s)
    No fault codes have been mentioned yet. But the g201 and 01130 are the most common. Scan it and see what it says.......
  1. Interchangeable exhaust.
    By 1stRaven in forum A8 - S8 - V8
    Last Post: 28-10-2013, 11:39 PM
  2. Are A6 and A8 wheels interchangeable?
    By A1GSS in forum Wheels and Tyres
    Last Post: 08-08-2012, 11:46 AM
  3. Interchangeable Parts
    By Degsy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-09-2010, 05:36 AM
  4. A6 interchangeable seats?
    By richard@fintek in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 31-01-2008, 09:39 AM
  5. Interchangeable T4 Engine
    By paintman in forum Archive posts
    Last Post: 28-12-2007, 10:18 PM
