Thread: Rear wiper will not stop on Golf mk5
  1. Rear wiper will not stop on Golf mk5
    Jul 2007
    checked wiring and realty’s and stalk. All ok.
    any ideas as I am lost here.
  2. Re: Rear wiper will not stop on Golf mk5
    Oct 2017
    London
    12 Post(s)
    Where did you check the wiring? Ive seen wires split when you open the boot and look up at the top left and top right corners. Get a scan done and see if it throws a clue.
  3. Re: Rear wiper will not stop on Golf mk5
    1841 Post(s)
    Wiper motor full of water
  4. Re: Rear wiper will not stop on Golf mk5
    Jul 2007
    His
    HOT THAT CLEAR YOUR MESSAGE.
    if the wires are split or broken then somethings in the boot will not work properly.
    For instance the rear wiper, locking latch for rear boot and the heated rear window.
    All the wiring goes through the top left and right hand boots.
  5. Re: Rear wiper will not stop on Golf mk5
    1841 Post(s)
    I had a good one a few months ago, a Toledo 2 V5 with the engine light on and a brake light circuit fault, in the end a blown fuse. The fuse kept randomly blowing over the next few weeks and had me pulling my hair out. In the end I found it was the boot mounted brake lights and if you opened the boot with your foot on the brake (?) the wires shorted inside the moulded tube. I made a quick fix and then ordered a new harness from Seat which they made specially and sent over in about a month.
  1. rear wiper wont stop wiping !
    By white.akita in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 04-10-2019, 07:38 AM
  2. Question Stop-start and auto-handbrake, rear wiper
    By mjwells in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 02-08-2014, 11:38 AM
  3. Rear wiper wouldn't stop wiping!!!
    By simonrk57 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-09-2012, 08:20 PM
  4. Rear wiper wont stop working ?????
    By mike ryan in forum Golf MK4 - 1999 - 2004
    Last Post: 11-05-2008, 03:57 AM
  5. Rear wiper won't stop!
    By Brian M in forum Golf MK3 - 1993 - 1999
    Last Post: 18-04-2007, 11:12 PM
