Thread: Quick dipstick question 3.0tdi
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: Quick dipstick question 3.0tdi
    Jan 2016
    Merthyr Tydfil
    25 Post(s)
    Thanks Dean ����
  2. Re: Quick dipstick question 3.0tdi
    May 2008
    40 Post(s)
    Quote Originally Posted by Johnny31 View Post
    Few on eBay...
    https://rover.ebay.com/rover/0/0/0?m...2F133057876880
    Sent from my mobile...
    John, thank you, I have ordered one.
    Its my wifes car and to get her to check the oil is a royal pita, plus the MMI wont let you check the oil on a cold engine, hence the want for a dipstick!
    Her two previous A6 C6 3.0tdi models had a dipstick.
  3. Re: Quick dipstick question 3.0tdi
    May 2008
    40 Post(s)
    New stick arrived, car on the flat engine hot, mmi shows oil 4mm ish below max, dipstick shows overfilled but its at the letter M on the word max so is showing 6 ish mm overfilled, so I can live with that and its so quick and easy, whilst checking other levels.
    So yes it works but not perfectly, you need to check what the mmi is showing to what is physically showing on the dipsick, just remember M is correct level.
  4. Re: Quick dipstick question 3.0tdi
    Oct 2019
    auckland, new zealand
    Hi, there is a fair bit of confusion out there with regards what goes in which engine; but my 2012 facelift Q5 with the 3.0 TDi motor has the AUDI PART 079 115 611 AB fitted and is a perfect match to the level shown by the MMI system.Yours should be the same even though a lot of the web based suppliers tell you it won't fit.
    Cheers and all the best from NZ
  1. Question A7 3.0tdi 272 dipstick
    By Bishop187 in forum A7 - S7
    Last Post: 21-11-2018, 01:01 AM
  2. 3.0TDI oil dipstick
    By buddyboy in forum A7 - S7
    Last Post: 20-01-2017, 03:56 PM
  3. 3.0tdi dipstick
    By s7gpt in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 23-02-2014, 11:20 PM
  4. 2.0TDI 143 Dipstick workaround part
    By Dieseldoos in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 28-01-2014, 03:28 PM
  5. quick question quick answer needed please
    By minty0_10 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-10-2008, 01:02 AM
