Thread: Touran Brake Light Problem
  1. Touran Brake Light Problem
    Aug 2019
    Liverpool
    Hi I need help asap as I'm currently on holiday with my car, the glow plug light stays on flashing and brake lights are permanently on and no cruise control, I had the car checked and the diagnosis was brake pedal switch but fuse 7 in the engine bay blew and blows instantly when changed. I've read somewhere this means the clutch pedal sensor? and disconnecting will fix the brake light problem? All help appreciated thanks
  2. Re: Touran Brake Light Problem
    1837 Post(s)
    The clutch pedal sensor is a Hall effect device on the master cylinder in the engine bay and is known for shorting out, unfortunately it uses the same power supply as the brake light switch.
  1. Touran brake light problem
    By D-MAN in forum Touran - Sharan - Caravelle
    Last Post: 24-08-2019, 05:21 PM
  2. touran brake light help
    By wullie in forum Touran - Sharan - Caravelle
    Last Post: 27-09-2011, 02:45 PM
  3. Please Help touran 3rd brake light
    By dadwagon in forum Touran - Sharan - Caravelle
    Last Post: 03-08-2009, 12:44 AM
  4. Touran - brake light
    By sood in forum Touran - Sharan - Caravelle
    Last Post: 05-01-2009, 06:46 PM
  5. Brake light problem on Touran
    By andrewwhite21 in forum Touran - Sharan - Caravelle
    Last Post: 16-04-2007, 02:58 PM
