Hey all,
Got myself a Golf Mk5 GT Sport 1.4tsi. Engine light is on so ran a scan with VCDS. Codes in system are....
009730 Coolant pump circuit short to ground.
008328 Camshaft A position actuator short to ground.
000052 Turbocharger bypass valve control circuit low.
000581 Solenoid valve for boost pressure (N75) short to ground.
001112 Evap system purge control valve (N80) short to ground.
008201 Intake manifold flap bank 1 short to ground.
001681 Fan 1 control circuit short to ground.
Has a new water pump fitted.
Has a new N75 valve fitted.
Has a new turbocharger bypass valve fitted.
I can clear the codes and the car goes ok for 10-15k's, then the MIL comes back on and looses power. I am getting some boost, but just revs forever on gears with no power.
Any ideas what to look at next?
Sent from my SM-G965F using Tapatalk
