Thread: ABS Fault
Results 1 to 8 of 8
  1. ABS Fault
    May 2014
    United Kingdom
    Hi folks just wondering if anyone can help with this fault... 00287 - ABS Wheel Speed Sensor; Rear Right (G44) 012 - Electrical Fault in Circuit
    I have replaced the sensor and the complete hub stiil light is on..i cant seem to clear the fault with vcds the light just stays on wiring looks ok but i can only see so much of it as it goes up past the fuel filler into the car.. there is another fault but dont know if this has anything to do with it..this is in the module instruments...1 Fault Found:
    00003 - Control Module
    014 - Defective thanks for any help
  2. Re: ABS Fault
    Jun 2016
    Glasgow
    Volt drop in wiring. Most likely at connector.
  3. Re: ABS Fault
    May 2014
    United Kingdom
    Thanks for the reply just wondering is it the connector at the wheel speed sensor or the abs control connector in the engine bay..
  4. Re: ABS Fault
    Mar 2017
    Nottingham
    9 Post(s)
    Did you fit a genuine sensor these eBay ones are a waste of time
  5. Re: ABS Fault
    May 2014
    United Kingdom
    Hi thanks for the reply yes its a genuine sensor had it on vcds today measuring block all sensors working but the rear right is dead or closed its starting to do my head in now just dont know where to start..need it of for m.o.t its my daughters car not long past her test just a runaround till she gets a year or so on the road..cheers mate.
  6. Re: ABS Fault
    1840 Post(s)
    You need to pin to pin check the wiring to the sensor at the ECU plug using a multimeter, I will look the PIN numbers up for you tomorrow if you remind me.
  7. Re: ABS Fault
    May 2014
    United Kingdom
    . Cheers mate that would be very helpful.
  8. Re: ABS Fault
    1840 Post(s)
    Remind me or the Vodka will delete my memory by the morrow....
  1. Please Help Touran 2006 1.9TDi Fault Code 18000 / P1592 MAP Sensor fault?
    By frozenman77 in forum Touran - Sharan - Caravelle
    Last Post: 12-01-2016, 12:31 PM
  2. Double Fault " Engine Fault - workshop & ESP Fault"
    By yusuf112 in forum Golf MK6 - 2009 - 2013
    Last Post: 10-02-2015, 10:23 AM
  3. Please Help engine management system fault& esp fault warning lamps coming on at same time.
    By passahat in forum Golf MK5 - 2004 - 2009
    Last Post: 02-03-2014, 09:22 PM
  4. Replies: 3
    Last Post: 19-02-2013, 02:10 PM
  5. Question AIRBAG FAULT warning light and VAGCOM Fault Code 00588
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-01-2009, 06:05 PM
