Thread: Strange noise when steering
Results 11 to 20 of 24
  1. Re: Strange noise when steering
    Liverpool
    11 Post(s)
    Afternoon all, topped up the power steering reservoir, it only took about 200ml to fill it to the 'max' line on the little dipstick. Left to right several times, and out for a 6 miles drive round the lanes, still full to the 'max' marker
    Out of interest, if i wanted to chage all the fluid (seeing as I have 1.8L of new stuff to use), how would i drain it all out? Is it a PITA to do?
  2. Re: Strange noise when steering
    Liverpool
    11 Post(s)
    Hello all
    Another question, since the low PS fluid issue, I've rechecked it several times and its still full. But, the car does make a pretty bad whine/droning when I turn, does that mean a knackered PS pump? Or could be something else? (Car is on 122k miles)
    How would i diagnose a knackered pump?
    And, what sort of a job is it in my 3.0 v6 petrol cab?
  3. Re: Strange noise when steering
    Jul 2007
    somerset
    8 Post(s)
    Check out the one way clutch on the alternator, these have a habit of seizing up and in turn causes the aux belt to flap around a lot more than it should, this then puts more strain on the belt tensioner and this will make a rumbling nasty noise especially when turning or on tick over. Lift the bonnet and see how much the tensioner if moving around when on tick over.
  4. Re: Strange noise when steering
    Liverpool
    11 Post(s)
    Thanks rhencullen
    had a new alternator fitted by a VAG specialist about 6 or 8 weeks ago so hopefully not that
  5. Re: Strange noise when steering
    Jul 2007
    somerset
    8 Post(s)
    I assume either a new alternator pulley was fitted or the new alternator came with one on it.
  6. Re: Strange noise when steering
    1840 Post(s)
    Would you describe the noise as a deep groan?
  7. Re: Strange noise when steering
    #17
    Liverpool
    11 Post(s)
    Quote Originally Posted by rhencullen1989 View Post
    No idea, it was done at a VAG specialist so guessing it would of been?
  8. Re: Strange noise when steering
    #18
    Liverpool
    11 Post(s)
    Hi Crasher
    Yeah I would, deep groan/chewbacka moaning kind of noise
  9. Re: Strange noise when steering
    #19
    1840 Post(s)
    This can be down to a known issue which is basically worn out gearbox oil that makes the diff groan.
  10. Re: Strange noise when steering
    #20
    Liverpool
    11 Post(s)
    Thanks Crasher, had a new clutch and DMF fitted 2 years ago (about 5k miles ago), would it not of been changed or replaced then?
    If not, how hard a job is it to do? (It’s the 6 speed manual gearbox)
  1. Steering gear fault. Steering rack box knocking noise
    By cip82 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 23-08-2020, 06:46 AM
  2. Please Help Strange noise when pulling off with some steering lock!
    By Steven L in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-02-2014, 05:08 PM
  3. Strange steering wheel noise
    By jonfun21 in forum Golf MK6 - 2009 - 2013
    Last Post: 11-03-2010, 01:59 PM
  4. Strange steering/wheel noise
    By denkatenka in forum A8 - S8 - V8
    Last Post: 11-02-2010, 02:10 PM
  5. Please Help Steering strange
    By BlueCaddy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-09-2008, 09:09 PM
