Thread: 2.0 diesel crank position sensor
  1. 2.0 diesel crank position sensor
    derbyshire
    hi, not had my passat for long and generally v happy with it.
    however last weekend, i got 2 errors on my diagnostics, one was related to glow plug 1 which i have now replaced and the error has cleared, the other error code appeared on saturday but hasnt re appeeared that code was P0322
    Its related to the crank position sensor, Ive ordered a new one but does anyone know where its fitted,
    mines a 14 reg passat
  2. Re: 2.0 diesel crank position sensor
    41 Post(s)
    922 Post(s)
    It is actually the speed sensor and is utterly evil to change. The oil filter housing has to come off (new gasket and bolts are a MUST) and then you have to get at the bolt using a 5mm ball end hex key as the access is not straight. Round out the head of the set screw and the next step is gearbox out and flywheel off so use a brand new key and take your time.
    "I disapprove of what you say, but I will defend to the death your right to say it"
    Evelyn Beatrice Hall (1868-1956)
  1. Crank Position sensor location?
    By MarkTM in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-08-2016, 02:32 PM
  2. Please Help G40 Crank Position sensor wiring
    By Demo8Dan in forum 1.9TDi - Engine
    Last Post: 20-05-2016, 07:12 PM
  3. Touran 170 2.0 tdi Crank Position Sensor
    By Saxonbridge in forum Touran - Sharan - Caravelle
    Last Post: 10-02-2013, 08:05 PM
  4. Please Help crank position sensor on VW BORA
    By riverwhy in forum Bora - 1998 - 2005
    Last Post: 27-08-2010, 05:35 PM
  5. Mk3 16v GTI crank position sensor-removal
    By dumyat in forum Golf MK3 - 1993 - 1999
    Last Post: 11-05-2007, 08:51 PM
