Thread: Passat B5.5 reprogramming spare key
  1. Passat B5.5 reprogramming spare key
    Jun 2012
    Oxford
    Help or advice required!
    I have a 2003 Passat B5.5 with two keys. When I first bought the car it had two working keys. When I tried the spare key today it is not working to lock/unlock the doors. The battery is fine because the light works. Upon doing some research I have seen how to reprogramme the spare key. Great...no!
    By using the working key I turn on the ignition (and wind down the window). Then I use the non working spare key to lock the car and then press the unlock button on the spare. The car makes a beep sound to indicate programming has been successful, however.....and this is the problem.....the working key currently in the ignition now does not lock/unlock the doors. It's as if the programming has been swapped over from the two keys.
    Does anyone have any ideas how I can get BOTH keys to lock/unlock the doors?
  2. Re: Passat B5.5 reprogramming spare key
    Just dug this out for you
    Re: reprogramming spare key / fob
    I kept searching the web and found this......good job I did coz no-one on this site knew the answer -
    Hi all,
    There are rumors flying that programming new remote key fobs to a Volkswagen is very easy. In order to correct any misinformation or misunderstandings related to this topic, I am writing this post to explain the details of the whole key matching process.
    Quick Overview of a Volkswagen Key
    A complete Volkswagen remote key fob consists of 2 parts: 1) the transmitter for radio remote control central locking system, and 2) main key with variable code transponder. If you lose either of these 2 parts you will not be able to start your car. But this will not happen because these 2 parts are tightly attached and it is not easy to separate them. The part numbers of these 2 parts for my Golf MK5 are shown below:
    1K0 959 753 G - The transmitter (the remote)
    1T0 837 246 INB - Main key with variable code transponder
    Main key is on the left, the transmitter is on the right. Picture is at Volkswagen Key Disassembly.
    Details
    So how to program a new key to your car? Firstly, you will need to make sure that you get the right remote. There are literally hundreds of frequencies for the remotes, and it has to be the exact one for the central locking controller to pick it up. You can easily verify this by checking the part number. The part number of all the remotes for Volkswagen Golf MK5 starts with HLO 1K0 959 753 and has a suffix letter at the end. The suffix represents the model and the frequency of the receiver/controller being used on your car. For example, the part number of my remote is HLO 1K0 959 753 G. The suffix G represents a specific model of the controller on my car with the frequency of 434MHz. The following is a list of part numbers of the remotes for Golf MK5 I observed so far:
    HLO 1K0 959 753 A - 434MHz for mobel PR-5D1
    HLO 1K0 959 753 B - 315MHz for model "J..": PR-5D3
    HLO 1K0 959 753 C - 315MHz for model "ROK": 5D5
    HLO 1K0 959 753 D - 315MHz
    HLO 1K0 959 753 G - 434MHz
    Please be reminded that the above part numbers may not be suitable for your car. Please check with your dealer and don't buy the wrong remote.
    Secondly, you need to find a locksmith who can cut the blade of a Volkwagen key. It shouldn't be too difficult to find one locally. Bring both of your keys (the existing and the blank key) to your locksmith and they will be able to replicate the key for you.
    Finally, you will need to programme the new key to your car. There are 2 parts to programme the remote.
    One for the doors (such that you can open/close doors and set/unset alarm using the remote)
    One for the car immobilizer (such that you can start your car)
    Part 1 is very simple. The following are the procedures:
    Place your first key into the ignition and turn to the second notch (do not start the car)
    Now close the door and place your second key into the handle lock
    Turn the key to the lock position and let it spring back to the central position.
    Hold down the Lock button on your new remote, you may hear a bleep from the car
    Now unlock the car using the key in the barrel and remove, then take your first key out of the ignition
    Close the door
    Your remote should now be coded
    Please be reminded that this procedure WILL NOT add your key to the immobilizer. Even you have completed part 1 and have the blade cut, you are still not able to start your car. This procedure will only code your key to connect to the controller so that you can open/close doors and set/unset alarm. However, this procedure can be used to re-activate an existing key that's lost its memory from a flat battery.
    Part 2 is the MOST difficult part. You will need the following to complete part 2:
    Volkswagen VAS 1551/5051/5052 or equivalent diagnostic equipment, OR
    A Windows-based computer with VAG-COM and the correct interface for your car, AND
    Secret Key Code (SKC)
    Secret Key Code (SKC) can only be obtained from an official dealership. There are 2 formats of SKC from VW. Prior to 2002, some vehicles were delivered with a scratch-off panel on a plastic tag. A 4-digit SKC was printed on that panel. Starting in 2002, dealerships implemented the WIN2 system to provide SKC's to their technicians and customers. As of 11 Mar. 2002, VW and Audi are providing 7-digit Secret Key Codes in place of the earlier 4-digit SKC's. Keys must be coded using the new 7-digit SKC (secret key code) method unless the owner still has the correct 4-digit code. 7-digital SKC is generated based on the 14-digital immobilizer ID with your 17-digit VIN. Once the 7-digit code has been generated, the 7-digit SKC, the date on which the code was generated by the dealer, along with the Workshop Code (WSC) and the Importer number of the dealer that generated the code must be entered to the VAS 1551/5051/5052 or VAG-COM in order to add new keys to the immobilizer.
    Recently, VW/Audi dealerships have switched to the new GeKo system, whereby their factory scan tools dial up the factory while connected to a car. Under this system, the technician no longer sees the SKC at all and you will need to bring your vehicle into the dealer to have immobilizer work performed. Note: GeKo connectivity requires VAS 5052 and broadband connection.
    Conclusion
    If you lose your key, you don't have much choice. Firstly, you need to get a blank new key. You can simply find one on eBay. But make sure that you get the right remote for your controller. If you still have the 4-digit SKC, then you will be able to add new key yourself using VAG-COM. Otherwise, you will need to take your car back to the dealer and have them do it for you. If you are lazy (like me), just request a new key from your dealer and they will order the key and program it to your car for you. But it will be very expensive.
    References and Acknowledgement
    Synchronise a new remote keyfobs: uk-mkivs Forum - The UK's Best Resource for the Golf MK4 MK5 MK6 MK7, Bora, Jetta and New Scirocco
    Ross-Tech VAG-COM FAQ: http://www.ross-tech.com/vag-com/faq_4.html#skc
    Key Matching Process: VW & Audi High Security Keys
    Volkswagen Key Disassembly: Volkswagen Key Disassembly
    Mingfinity: he is so brave to disassemble his key and check the part number and the frequency of his remote
    golfer: for verifying the part number and the frequency of a specific remote
    Aric (uk-mkivs.net): for verifying some of the part numbers and the models of several controllers/receivers
    ETKA
    Official Volkswagen Service Manual
    I hope this helps. If you find any incorrect information in this post, please feel free to correct me. Thanks.
  3. Re: Passat B5.5 reprogramming spare key
    1840 Post(s)
    It could be a faulty key even though the light works, you need a diagnostic computer system such as VCDS to program the key back in if it has gone out of sync which can happen.
  1. reprogramming spare key / fob
    By mikegally in forum Golf MK5 - 2004 - 2009
    Last Post: 22-07-2017, 10:48 PM
  2. B6 Passat tdi spare key ?
    By spadders in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-07-2013, 01:00 PM
  3. Passat spare key
    By diesel 6 in forum New Member Introductions
    Last Post: 19-06-2009, 10:51 AM
  4. Matching / reprogramming spare key / fob
    By Ben in forum VCDS - General Questions
    Last Post: 19-02-2009, 08:27 PM
  5. Reprogramming the remote control of 2004 PASSAT
    By archibald_999 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-10-2008, 02:59 PM
