Thread: Please help Starting problem when hot
  1. Please help Starting problem when hot
    Aug 2019
    uk
    Help needed please
    Has anyone had any starting problems with their A6 after a run when the engine is hot?
    I have a 2007 2.0 tdi A6 BRE, she starts first time every time when the engine is cold but i have an intermittent problem sometimes when hot, The starter motor sounds really sluggish like the battery has gone completely flat even though its fully charged, leave it for 60 seconds and she fires up no problem at all.
    so far i have replaced the following:
    2 x bosch s5 013 830A batterys
    2 x bosch starter motors
    clutch in to start switch and checked and cleaned both earth to chassis straps.
    problem persists and no faults found in vcds
    any help would be much appreciated.
  2. Re: Please help Starting problem when hot
    Aug 2018
    GB
    I think the best thing to do is to have the car scanned for codes, otherwise you'll end up gambling with buying and replacing unnecessary parts. I'm experiencing a starting issue myself, however when researching online I stumbled upon several posts where people suggested that it may be one of the temp sensors telling the (warm) engine that it is in a cold state, thus throwing more fuel into the warm engine than necessary, causing it tk flood a bit. This issue would normally go away after 10 - 30 min of wait time. I thought I had the same issue, however when scanned for codes it now comes with relay short circuits, etc. So do check for codes first.
  3. Re: Please help Starting problem when hot
    1840 Post(s)
    That sounds like fuel leaking into the cylinders, how is the oil level behaving?
  1. Please Help 2001 1.9TDI power problem, freezing trip computer and starting problem
    By chapster in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-10-2014, 12:44 PM
  2. Please Help starting problem
    By finechtyphill in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-08-2013, 03:14 PM
  3. starting problem and taking of problem
    By joeyjoe24 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-03-2010, 01:59 PM
  4. Exhaust emissions/temperature gauge problem/starting problem
    By joncope in forum Polo - Derby - Lupo - Fox
    Last Post: 06-07-2009, 04:31 PM
  5. A4 starting problem
    By A4-v6 in forum Chat - Anything with wheels
    Last Post: 16-12-2008, 04:45 PM
