Thread: A6 C6 clutch replacement
  1. A6 C6 clutch replacement
    Sep 2012
    Romford, UK
    I have a 56 plate manual transmission Audi A6 with 168K miles on it. I find that it hesitates while accelerating. Sometimes if I push the accelerator, the rpm goes up high and then drops. I am still able to drive at highway speeds, but it just accelerates very slowly. I checked in a local Garage and he said the clutch needs replacing, without a test ride or any diagnostics. I see clutch replacement is quite expensive. Is this an obvious issue/wear&tear at this mileage or could this be something else?
    If it's the clutch, what are the parts involved? I can see the following on eurocarparts. Is this what I need to buy?
    Clutch Kit: |Car PartsRetailer | Euro Car Parts
    Flywheel: |Car PartsRetailer | Euro Car Parts
  2. Re: A6 C6 clutch replacement
    Southampton, UK.
    Sounds like a clutch replacement to me. Had A3 2.0 TDI (LUK + flywheel) clutch dune recently, cost just over £800, just to give you an idea. If you're sourcing the parts yourself, speak to the shop yourself - they will probably be able to identify the exact clutch kit needed (eg. LUK or Sachs).
    2003 VW Golf Est 1.9 TDI 130
    2006 Audi A3 2.0 TDI Sport 140
  3. Re: A6 C6 clutch replacement
    Sep 2012
    Romford, UK
    Thanks for the info. I will check with the Shop on the exact parts required.
  1. Question Mk5 GT TDI 07 clutch replacement
    By lbaldy14 in forum Golf MK5 - 2004 - 2009
    Last Post: 21-06-2015, 10:51 AM
  2. DMF and Clutch replacement
    By simonrk57 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-03-2013, 10:03 PM
  3. clutch replacement
    By gadgee in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-03-2010, 10:01 PM
  4. Question Clutch and DMF Replacement
    By elPaulio in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 27-02-2010, 10:07 PM
  5. Clutch replacement?
    By BoraTdifan in forum Bora - 1998 - 2005
    Last Post: 01-01-2008, 04:21 PM
