Thread: 2.0 tdi. manual. cbbf. oil leak
Results 1 to 8 of 8
  1. 2.0 tdi. manual. cbbf. oil leak
    May 2009
    uk
    hiya,
    at this minute in time i dunno how to upload a video.... but... here is a pic
    i know the fly wheel is knocking and needs changing... but i also have a oil leak where the arrows are... like 5 drips per second along this seal... whilst engine running
    any idea what it could be... i have an idea but like to hear your opinion
  2. Re: 2.0 tdi. manual. cbbf. oil leak
    1841 Post(s)
    Has any work been done recently such as sump, oil filter or housing removal?
  3. Re: 2.0 tdi. manual. cbbf. oil leak
    May 2009
    uk
    no idea just bought from auction... it had a small tub wedged in the under tray catching the oil
  4. Re: 2.0 tdi. manual. cbbf. oil leak
    May 2009
    uk
    just looked it deffo looks like sump has been off
  5. Re: 2.0 tdi. manual. cbbf. oil leak
    1841 Post(s)
    Could just be a badly refitted sump, you have to be very precise with it. The real worry is if it is the crank oil seal.
  6. Re: 2.0 tdi. manual. cbbf. oil leak
    May 2009
    uk
    i thought crank oil seal too.
    is the crank oil seal a big job on these ?
  7. Re: 2.0 tdi. manual. cbbf. oil leak
    May 2009
    uk
    well its either the rms or sump... got car up and right under....
    its leaking right under rms... but may be sump as them 2 end bolts look a bit crappy to tighten up.
    so im gunna remove sump... clean up & get some new bolts and fasten up.
    just need to find correct torque settings for them.
    it needs dmf doing soon, so rms at same time wont be too much extra work
  8. Re: 2.0 tdi. manual. cbbf. oil leak
    1841 Post(s)
    The seal also means the sump off and a multi step process using a special jig to install and align the seal which is also the crank speed sensor ring.
  1. A6 Repair Manual - Is there a Haynes type manual for an A6 ?
    By SLINEA6 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-10-2015, 09:42 AM
  2. A6 C5 2.5Tdi Manual Allroad....washer bottle leak !
    By Big Ant in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-04-2015, 05:21 PM
  3. Service manual of aaaaaaavw bora 1.6L manual(2003-2005)
    By tolasam2002 in forum Bora - 1998 - 2005
    Last Post: 05-03-2014, 12:28 PM
  4. Please Help Troubleshooting on my first car - A4 Avant estate 1999 - A-frame water leak, footwell leak etc.
    By damn_seagulls in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-01-2014, 10:02 PM
  5. Question Can I use "Automatic Transmission Stop Leak" to fix my manual gear box leak?
    By MysticMartin in forum Golf MK3 - 1993 - 1999
    Last Post: 20-02-2012, 02:54 PM
