Thread: A4 Starts But Immediately Stalls
  1. A4 Starts But Immediately Stalls
    Jun 2019
    Sherborne, Dorset
    My 1.9 TDI starts but immediately stalls. The engine light is illuminated and the one time I got it to run it was in limp mode which was enough to get me home. It's been moored to the drive since the week before last now.
    I've now bought a Gendan diagnostic cable and invested in VCDS-Lite. I checked the fault codes this morning but I can't really decipher what it's saying to me.
    I've done some Googling on the matter and there's various possible causes such as fuel pump failure and ECU issues but I'm wondering if perhaps it's the immobiliser that's the problem. Starting and immediately stopping is what it did when I had a new key cut a few weeks ago and the chap that did it tried the ignition to see that it fitted before he cloned the chip.
    I also notice that the immobiliser light in the instrument panel doesn't illuminate at all so I'm wondering if a previous owner had removed the bulb. I'll check that out later once the rain stops.
    Here is the VCDS report of the various faults, if someone more knowledgeable on VCDS can take a let and let me know your thoughts that'd be great ...
    VCDS-Lite Version: Release 1.2
    Saturday, 10 August 2019, 13:26:56:45583
    Chassis Type: 8E - Audi A4 B6
    Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56 ,57,65,67,69,75,76,77
    Address 01: Engine Labels: 038-906-019-AVF.LBL
    Controller: 038 906 019 LJ
    Component: 1,9l R4 EDC G000AG 5934
    Coding: 00001
    Shop #: WSC 63251
    VCID: 6AA7F3A40567
    WAUZZZ8E54A227828 AUZ6Z0D0045638
    5 Faults Found:
    17957 - Boost Pressure Regulation Valve (N75): Open or Short to Ground
    P1549 - 35-10 - - - Intermittent
    17932 - Fuel Pump Relay (J17): Open or Short to Ground
    P1524 - 35-00 - -
    17849 - EGR Valve (N18): Open Circuit or Short to Ground
    P1441 - 35-10 - - - Intermittent
    18027 - Glow Plug Relay (J52): Open or Short to Ground
    P1619 - 35-10 - - - Intermittent
    18080 - Coolant Fan Control 1: Open or Short to Ground
    P1672 - 35-10 - - - Intermittent
    Readiness: N/A
    Address 02: Auto Trans Labels: 01J-927-156.LBL
    Controller: 8E2 910 155 B
    Component: V30 01J 1.9l PD RdW 3271
    Coding: 0000001
    Shop #: WSC 00178
    VCID: 263FC794D1FF
    2 Faults Found:
    18265 - Load Signal: Error Message from ECU
    P1857 - 000 - - - Intermittent
    18270 - Powertrain Data Bus: Missing Message from Instrument Cluster
    P1862 - 000 - - - Intermittent
    Address 03: ABS Brakes Labels: 8E0-614-517.LBL
    Controller: 8E0 614 517
    Component: ABS/ESP front 3429
    Coding: 04259
    Shop #: WSC 06435
    VCID: E5BD00986C79
    No fault code found.
    Address 08: Auto HVAC Labels: 8E0-820-043.LBL
    Controller: 8E0 820 043 AC
    Component: A4 Klimaautomat 1450
    Coding: 00000
    Shop #: WSC 00000
    VCID: 62B79B84FD57
    1 Fault Found:
    01312 - Powertrain Data Bus
    79-00 - Please Check Fault Codes
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL
    Controller: 8E0 907 279 F
    Component: int. Lastmodul RDW 0517
    Coding: 00001
    Shop #: WSC 63251
    VCID: 351D10D81C59
    Address 15: Airbags Labels: 8E0-959-655-84.LBL
    Controller: 8E0 959 655 J
    Component: Airbag 8.4EP 1002
    Coding: 0010602
    Shop #: WSC 63251
    VCID: 3E0F0FF4296F
    Address 16: Steering wheel Labels: 8E0-953-549.LBL
    Controller: 8E0 953 549 N
    Component: Lenksáulenmodul 0611
    Coding: 00042
    Shop #: WSC 63251
    VCID: 3E0F0FF4296F
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
    Controller: 8E0 920 950 M
    Component: KOMBI+WEGFAHRS. RB4 D42
    Coding: 00401
    Shop #: WSC 00001
    VCID: 33192EC0122D
    Address 37: Navigation Labels: None
    Controller: 8E0 035 192 Q
    Component: RNS-E HIGH EU H73 0650
    Coding: 0301117
    Shop #: WSC 06335
    VCID: 32172BC4ED37
    3 Faults Found:
    00856 - Radio Antenna
    011 - Open Circuit
    00857 - CD Changer Unit (R41)
    004 - No Signal/Communication
    00466 - Control Module for Steering Column Electronics (J527)
    008 - Implausible Signal
    Address 45: Inter. Monitor Labels: 8E0-951-177.LBL
    Controller: 8E0 951 177
    Component: Innenraumueberw. 0704
    Coding: 00001
    Shop #: WSC 00000
    VCID: EBA976A08A9D
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
    Controller: 8E0 959 433 BC
    Component: Komfortgerát T3B 1412
    Coding: 01931
    Shop #: WSC 73430
    VCID: 7399EEC052AD
    Address 56: Radio Labels: None
    Coding: 0301117
    Shop #: WSC 06335
    VCID: 32172BC4ED37
    3 Faults Found:
    011 - Open Circuit
    Address 76: Park Assist Labels: 8E0-919-283-8E2.LBL
    Controller: 8E0 919 283 A
    Component: Parkingsyst. A4 RDW D08
    Coding: 01114
    Shop #: WSC 63251
    VCID: 2E2F3FB4F90F
    End --------------------------------------------------------------------------------------------------
  2. Re: A4 Starts But Immediately Stalls
    Jun 2019
    Sherborne, Dorset
    Well it would seem that my instruments don't have the immobiliser light. I thought they all had them.
  1. Car starts and dies immediately
    By BlackMk4 in forum Golf MK4 - 1999 - 2004
    Last Post: 18-08-2016, 05:56 PM
  2. 2.0 FSI Starts then immediately stalls?
    By samrimmer in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-07-2014, 09:54 PM
  3. Starts then Immediately Cuts Out
    By MarkSRose in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 20-01-2013, 01:11 PM
  4. Please Help GTI 16v starts then immediately dies!
    By mikecarty51 in forum Golf MK3 - 1993 - 1999
    Last Post: 29-08-2008, 08:17 PM
  5. A3 2.0 Fsi Engine starts but cuts out immediately
    By A3_2FSI in forum Audi A3 - Archive Topics
    Last Post: 13-02-2008, 12:43 AM
