Thread: Aircon problems
Results 1 to 10 of 11
  1. Aircon problems
    I am having problems with my aircon, it works well when on tickover but does not cool when revs climb over 1200. I have checked with VCDS, the solenoid valve duty cycle stays at 60% and the current at 0.6 A but the discharge pressure drops from 15 Bar to 5 Bar, the compressor status stays at on, no fault codes are logged. At first I thought it was the safety clutch slipping at higher revs but if I put a spanner on the centre nut I can turn the pulley so I think the clutch is fine. I am convinced it is a faulty solenoid valve not controlling the swash plate angle when the revs increase, has anyone had these symptions with a faulty solenoid?
  2. Re: Aircon problems
    Sep 2008
    chester
    17 Post(s)
    I would get some gauges on the hi/low sides and see the actual pressure,could be short of gas.
  3. Re: Aircon problems
    1837 Post(s)
    Have we! The number of these modern variable displacement compressors we change is ridiculous, the MQB platform is particularly prone.
  4. Re: Aircon problems
    Quote Originally Posted by nevo View Post
    VCDS give pressure readings, these are fine untill the revs climb.
  5. Re: Aircon problems
    Sep 2008
    chester
    17 Post(s)
    I would say if the discharge press drops to 5 bar there's a insufficient gas on the suction anyway if you decide to change the solenoid valve you'l have to evac the system so you can check what the actual pressures are.
  6. Re: Aircon problems
    My first thought, I had the gas topped up 3 weeks ago, it made no difference. I think the extra force on the swash plate due to the revs increasing is sufficient to overcome the faulty valve and square up the swash plate on the shaft thus producing zero discharge, I will get back and report what I find.
  7. Re: Aircon problems
    1837 Post(s)
    I saw that on a T5 a few weeks ago, it was the compressor.
  8. Re: Aircon problems
    Hi Crash, I hope you don't mean that you changed the control valve and it still did not work! or do you mean that you just changed the compressor to make sure it did not come back in?
  9. Re: Aircon problems
    1837 Post(s)
    I never change the valve, it is not a VAG approved way of dealing with the problem.
  10. Re: Aircon problems
    Thats nice to know, I still have hope with the valve change.
  1. Important Aircon Problems
    By Evobully in forum Golf MK4 - 1999 - 2004
    Last Post: 02-06-2017, 12:04 PM
  2. A4 2003 aircon problems
    By besi_05 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-06-2014, 12:08 PM
  3. Please Help Aircon Problems!!!
    By gumballforever in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-08-2012, 07:33 PM
  4. Aircon problems, please help lol
    By iparkes in forum Golf MK4 - 1999 - 2004
    Last Post: 26-06-2011, 06:02 PM
  5. Aircon/blower problems
    By smudge1101 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-10-2010, 07:28 AM
