Thread: P2196
  1. P2196
    Jul 2019
    west midlands
    Hi I have the code P2196 on my b6 passat 2008 2.0 tdi cr
    I changed the bank1 sensor1 lambda cleared the cel but 20 miles later Light is back on.
    Can anybody assist?
    Ive just turned the light off. so will post freeze frame asap
  2. Re: P2196
    Jul 2019
    west midlands
    Here is the freeze frame data can anybody assist please
    Freeze frame
    Freeze frame DTC P2196
    Calculated Engine load value 0%
    Engine coolant temperature 85 oc
    Intake manifold absolute pressure 98 kPa
    Engine RPM 1452 rpm
    Vehicle speed 50 km/h
    Intake air temperature 26 Oc
    MAF air flow rate 22.99 g/sec
    Throttle position 83%
    Fuel rail press. 46870 kPa
  3. Re: P2196
    Jul 2019
    west midlands
    just a thought could this be a faulty MAF due to the engine load value showing 0%?
  4. Re: P2196
    1841 Post(s)
    Which part number did you fit?
  5. Re: P2196
    Jul 2019
    west midlands
    I just did the o2 sensor on bank 1 sensor 1
    trying a bit of trial and error atm
  1. Lambda P2196 - 000 - Signal too High (Rich) and
    By s1paulj in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-08-2017, 11:51 PM
