Thread: Gearbox problem ??
  1. Gearbox problem ??
    Hi to All,
    2010 , A4B8 auto Quattro petrol, 44000 Klms.
    I have been persisting with a jerky start when taking off from stationary position. If I am very very soft on the accelerator it seems in control, I mean painfully soft.
    If I take off from rest up a small incline or down a slope there is no indication of this jerkiness. It appears that when there is some preload on the drive system, all seems better.
    At registration time a mechanic suggested possible low on transmission fluid, although I am not dropping any oil. I believe the trans oil change is quite expensive, and at 44K a little early.
    Moving very slowly in forward and in reverse is not at all smooth, as if there is MAJOR back lash in the tail shaft.
    If I was a betting man, I would think that the turbo is cutting in too early, unlikely.
    There is a big back lash problem somewhere.
    And if it was a manual I would have a twisted ( worpted, that does not look right ) clutch plate.
    Without further input from the Forum I will be off to the Dealers.
    I welcome your replies.
    Best regards
    John
  2. Re: Gearbox problem ??
    Apr 2018
    N.Ireland
    9 Post(s)
    Hi John,
    can you log your air and fuel with vcds? I had a 2010 petrol with a CVT box not sure what yours is. there are a few things which help maintain a good air fuel mix, air flow meter, lambdas, fuel filter, fuel pump. these may be easier to diagnose than the gearbox itself which i hope it isn't for you.
  1. New gearbox problem, what is it?
    By a4_jim in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-10-2012, 05:25 PM
  2. Please Help Gearbox Problem
    By essayeff in forum Golf MK3 - 1993 - 1999
    Last Post: 24-08-2010, 10:34 AM
  3. Problem with VAG DSG Gearbox?
    By stuart in forum Chat - Anything with wheels
    Last Post: 21-01-2010, 12:51 AM
  4. problem with gearbox????
    By jwelsh12 in forum Golf MK4 - 1999 - 2004
    Last Post: 22-11-2008, 01:32 AM
  5. GEARBOX PROBLEM help please
    By Iainip in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-11-2007, 04:44 PM
