Thread: Red battery light on dashboard
  1. Red battery light on dashboard - new alternator
    Liverpool
    11 Post(s)
    2003, A4 3.0 petrol, battery light on dash. 2 questions:
    1) can I still use it to commute? (5 miles each day)
    2) what could it be, and best way to fault find please? It had a battery about 6 years ago I think
    Help! Cheers guys
  2. Re: Red battery light on dashboard
    Near Blackpool
    48 Post(s)
    Alternator not charging. Put a meter on the battery when it’s running. If it’s not 13.2 or above it’s goosed.
  3. Re: Red battery light on dashboard
    Liverpool
    11 Post(s)
    Thanks Jonathan, will check it soon as I'm home.
    If the alternator is goosed (I've read a few other forums it could be that), what's it like to get to and change on the 3.0 v6 petrol?
    Also, I had the camebelt done last week, could it be linked to that, or not?
  4. Re: Red battery light on dashboard
    Near Blackpool
    48 Post(s)
    Did you get the auxiliary belt changed as well? I’d be tempted to ask them to check that they have done it correctly and the belts not slipping or nudged the earth off the alternator. Not sure on ease, can’t imagine it being too hard to change if need be. Like I say could just be a disturbed earth/slipping belt.
  5. Re: Red battery light on dashboard
    Liverpool
    11 Post(s)
    I dont think they done the aux belt as well. I just measured the battery voltage, switched off: 12.38v. Car running: 11.98v
    Knackered battery maybe?
  6. Re: Red battery light on dashboard
    Near Blackpool
    48 Post(s)
    Nope that’s the alternator not charging. It’ll run till the battery goes flat. It’s not safe to drive as it will just cut out as it’s a petrol
  7. Re: Red battery light on dashboard
    Liverpool
    11 Post(s)
    Thanks again Jonathan. Just dropped it off for a new alternator. Been told there are 3 different types for this model. So they won’t know which one I need until it’s removed
  1. Please Help Battery Replaced, Now Airbag and Traction Control Light On Dashboard
    By chesterman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-01-2017, 12:19 AM
  2. Replies: 0
    Last Post: 23-08-2015, 06:34 PM
  3. Please Help Dashboard lighting problem - roof light flashing, no parking brake light etc
    By 95cabrio in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 14-12-2011, 07:21 PM
  4. Audi A4 Dashboard Instrument Panel Light Bulb Dash Light Fix
    By cbi004 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-07-2011, 08:39 AM
  5. BATTERY LIGHT ON 2.7TDi Q 2005 - NO BATTERY CHARGE
    By shairaz1 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-07-2009, 02:05 AM
