Thread: Replacing rear discs abd pads on 2014 Touareg 7P with EPB
Results 1 to 10 of 13
  1. Replacing rear discs abd pads on 2014 Touareg 7P with EPB
    Aug 2007
    Hook Hampshire
    18 Post(s)
    I am changing the rear discs and pads for a 2014 Touareg 7P 52PJ and brakes code 2EG. My question is:
    Can I replace the disc without having to use VCDS on basic settings to retract the parking brake before I do any work? Ross Tech seems to suggest that this is OK.
    I appreciate that once the discs are changed I will have to use VCDS to measure the air gap to ensure it is within spec. If not in spec I will have to adjust the shoes to be within spec. But after doing that, do I need to use basic settings to reset the electronic parking brake, or just measure the air gap.
    Audi A7 Dakota Grey, 3.0TDi 2wd, engine CLAB, Gearbox NKP, Comfort seats, parking system advance, advance key, MMI Nav plus, MMI touch, HUD, Mob phone prep high with on-line services, heated sports steering wheel, folding mirrors, garage opener, fine grain ash inlays. 137k miles
    Audi Q5, 3.0TDi Sline Plus engine CDUD, adaptive headlamps, high beam assist, black inlays, advance key, TPMS, parking sys advanced, 70k miles. Audi R8 spyder Plus in vegas yellow 4K miles
  2. Re: Replacing rear discs abd pads on 2014 Touareg 7P with EPB
    36 Post(s)
    830 Post(s)
    Beware, this can turn into a total sketch that not even VCDS can deal with. I use either Delphi which has it sussed or ODIS which is slow, painful and expensive. Even if you don’t change the shoes they still have to be gapped to the drum at approx 1.8mm and then “ground in” and this is a process that to be honest is daft, the instruction tells you to drive at a steady speed of around 30 Km for approx 500 meters in a straight line without varying whilst it grinds the drums into the shoes to set up the electric parking brake. Now I have got it sussed and unfortunately end up with local garages bringing them to me to set up, like last Friday at 4pm and I was like, “yeh, Monday but not now!”
  3. Re: Replacing rear discs abd pads on 2014 Touareg 7P with EPB
    Aug 2007
    Hook Hampshire
    18 Post(s)
    Thanks form the advice Crasher. I enter the Lions Den tomorrow, and will tread with extreme caution. I am a sucker for a challenge. If I fall! it will cost me in terms of reputation and financially but then, the experience will enlighten me hopefully.
    I may be making an SOS call to a Crasher type Co near Basingstoke.
    I will keep you updated.
  4. Re: Replacing rear discs abd pads on 2014 Touareg 7P with EPB
    Aug 2007
    Hook Hampshire
    18 Post(s)
    A bit of a false start this morning. I thought the calliper bolts were M12 spline, but they turned out to be M14. I called a dozen motor factors and tool shops and none had them in stock. so I will try again after my customer comes back from holiday.
    However I looked at a few bits of data on VCDS. Looking at module 53. Parking brake, I get the following options, but no option to retract the EPB. The protocol is UDS. Any idea? I may have to upgrade my aging laptop which still runs of Windows XP. Another interesting point was that in looking at advanced measurements. The airgap on the left was 2.350mm and the right was 2.502mm, so the right is just outside spec. Max is 2.400mm
  5. Re: Replacing rear discs abd pads on 2014 Touareg 7P with EPB
    36 Post(s)
    830 Post(s)
    Which level of VCDS are you using?
  6. Re: Replacing rear discs abd pads on 2014 Touareg 7P with EPB
    Aug 2007
    Hook Hampshire
    18 Post(s)
    problems seeing Module 53 options on a Touareg
    If you mean the software version, I am using VCDS release 19.6.1 on Windows XP.
    In case you cant read the picture. The options are as follows:
    Static current measuring mode
    Air gap calibration
    Electromechanical parking brake erase activation counter
    Lamp Test
    Reset start up
    Setze Einschleif-Zustand
    Its UDS protocol. Why cant I see the option to retract or replace the parking brake linings.
    I have tried this on my A7 and I can see the options to retract and change the brake linings.
  7. Re: Replacing rear discs abd pads on 2014 Touareg 7P with EPB
    Mar 2020
    Uk
    Hi all new to this forum so thank you for any help in advance. I have a 2014 Touareg I took the car in to a local garage to have front and back pads replaced they then told me they needed car for longer as could not get a coed to set breaks. After 2 days the car was big with them but had been sent to a main dealer they said that they had wiped the program of the system and because the hand break shoes had not been replaced the program wonít work because they are half worn. The main dealer told me that the garage that had the car should not have needed to plug anything in to replace pads. Now Iím left with a warning light on. They are telling me that the shoes need replacing so the hand break can calibrate has anyone had this problem thanks John
  8. Re: Replacing rear discs abd pads on 2014 Touareg 7P with EPB
    Aug 2007
    Hook Hampshire
    18 Post(s)
    What the main dealer says sounds correct. I guess that your first garage retracted the electronic handbrake which means that the brake shoes needed to be ground in. When the grounding in was attempted, the clearance between the shoes and disc was probably greater than specification, so its needed new shoes to reduce the gap. I think you just need to let the dealer get on with it. Expensive though.
    When I did the job, I managed to get the discs off without retracting the handbrake shoes, so no grinding in process was required.
  9. Re: Replacing rear discs abd pads on 2014 Touareg 7P with EPB
    36 Post(s)
    830 Post(s)
    This is a common and really painful problem, I have to deal with it on a regular basis for other garages. I have not been able to get VCDS to complete the process and initially I used a friends Delphi diagnostic system which worked but now I use the dealer system ODIS. The shoes don't need replacing if they not worn or corroded, the air gaps have to be set manually and then the shoes bedded in using the diagnostic system.
  10. Re: Replacing rear discs abd pads on 2014 Touareg 7P with EPB
    Aug 2007
    Hook Hampshire
    18 Post(s)
    Thanks for the clarification Crasher
  1. Replacing rear discs & pads
    By bloodworm in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 02-01-2015, 10:13 PM
  2. Replacing Lupo discs/pads
    By Trout13 in forum Polo - Derby - Lupo - Fox
    Last Post: 05-07-2012, 01:37 PM
  3. replacing front and rear brake discs and pads
    By ads_ali in forum Golf MK5 - 2004 - 2009
    Last Post: 19-06-2009, 10:41 PM
  4. Replacing rear discs and pads on a 97' TDI
    By bagseye in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-05-2009, 03:02 PM
  5. Question T4 Replacing Pads + Discs
    By V10SURFA in forum The Commercial Range
    Last Post: 15-08-2008, 08:49 PM
free web
stats
