Thread: Replacing rear discs abd pads on 2014 Touareg 7P with EPB
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. Re: Replacing rear discs abd pads on 2014 Touareg 7P with EPB
    Aug 2007
    Hook Hampshire
    21 Post(s)
    What the main dealer says sounds correct. I guess that your first garage retracted the electronic handbrake which means that the brake shoes needed to be ground in. When the grounding in was attempted, the clearance between the shoes and disc was probably greater than specification, so its needed new shoes to reduce the gap. I think you just need to let the dealer get on with it. Expensive though.
    When I did the job, I managed to get the discs off without retracting the handbrake shoes, so no grinding in process was required.
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  2. Re: Replacing rear discs abd pads on 2014 Touareg 7P with EPB
    1840 Post(s)
    This is a common and really painful problem, I have to deal with it on a regular basis for other garages. I have not been able to get VCDS to complete the process and initially I used a friends Delphi diagnostic system which worked but now I use the dealer system ODIS. The shoes don't need replacing if they not worn or corroded, the air gaps have to be set manually and then the shoes bedded in using the diagnostic system.
  3. Re: Replacing rear discs abd pads on 2014 Touareg 7P with EPB
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Thanks for the clarification Crasher
  1. Replacing rear discs & pads
    By bloodworm in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 02-01-2015, 10:13 PM
  2. Replacing Lupo discs/pads
    By Trout13 in forum Polo - Derby - Lupo - Fox
    Last Post: 05-07-2012, 01:37 PM
  3. replacing front and rear brake discs and pads
    By ads_ali in forum Golf MK5 - 2004 - 2009
    Last Post: 19-06-2009, 10:41 PM
  4. Replacing rear discs and pads on a 97' TDI
    By bagseye in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-05-2009, 03:02 PM
  5. Question T4 Replacing Pads + Discs
    By V10SURFA in forum The Commercial Range
    Last Post: 15-08-2008, 08:49 PM
