Thread: 2.0 tdi to 1.9 tdi swap?
Results 1 to 8 of 8
  1. 2.0 tdi to 1.9 tdi swap?
    Jul 2019
    Cornwall
    Hi everyone, has anyone done this swap? I have a nice B7 2.0 tdi ( blb) with a broken oil pump,and a battered b6 with a sweet 1.9 tdi (awx). Is there any reason I can't swap the awx into the B7? If so is there a best combination of parts to use? Thanks in advance
  2. Re: 2.0 tdi to 1.9 tdi swap?
    May 2012
    Everywhere
    308 Post(s)
  3. Re: 2.0 tdi to 1.9 tdi swap?
    Jul 2019
    Cornwall
    I don't think that will help as I'm sure the blb is ruined. ☹️
  4. Re: 2.0 tdi to 1.9 tdi swap?
    Jul 2019
    Cornwall
    I'm sure the Awx will physically fit, I'm just not sure how far back I'll have to go changing bits, i.e. Engine loom, Ecu, dash clocks? Is the awx b6 loom compatible with the B7? Surely this conversion has been done before?
  5. Re: 2.0 tdi to 1.9 tdi swap?
    108 Post(s)
    1816 Post(s)
    It will fit but the electronics could be a total sketch and leave you will malfunction lights impossible to turn off which would be a disaster. With the punitive emissions taxes coming on non EU6 diesel it is not worth putting good money into them.
  6. Re: 2.0 tdi to 1.9 tdi swap?
    Jul 2019
    Cornwall
    Thanks for the reply, I appreciate that it could be a tough one to sort out. I only paid £450 for both cars , and the nice one is a B7 s line avant with 70k on the clock and is mint so I don't mind spending the time. Surely if I work back far enough through the car they should interface at a common point? having both complete cars should help I guess!
  7. Re: 2.0 tdi to 1.9 tdi swap?
    108 Post(s)
    1816 Post(s)
    The crux of the job will be getting the dashboard to talk to the engine ECU and the ABS and other connected devices to not get upset, you issues are most likely to be software related.
  8. Re: 2.0 tdi to 1.9 tdi swap?
    Jun 2020
    Kildare Ireland
    Any update on this ?
  1. 1.9 tdi ecu swap
    By markvw in forum 1.9TDi - Engine
    Last Post: 15-11-2015, 12:36 PM
  2. SKC ecu swap
    By Troyboy9061 in forum VCDS - Help Requests
    Last Post: 16-08-2015, 10:46 AM
  3. PB - EV Swap
    By mercedeslimos in forum Golf MK2 - 1984 - 1992
    Last Post: 12-06-2011, 05:22 PM
  4. Please Help Passat Headlight swap, is it posible to swap early / late over?
    By scotlandstu in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-05-2009, 11:26 AM
  5. swap
    By vetalik in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-11-2007, 07:28 PM
