Thread: Vw Caddy 2.0 SDi misfire on cylinder 3
  1. Vw Caddy 2.0 SDi misfire on cylinder 3
    Oct 2006
    Collier Street
    Hi all
    I've got a misfire on cylinder 3 & have noticed that when I undo the fuel filler cap there is a hiss of air. I'm assuming that something is blocked & air is not getting into the tank as I'm using diesel, therefore creating a vacuum in the tank. Would this cause the misfire & why would it only be on 1 cylinder?
    I've already changed the injector loom as that was the cheapest possible cause of the misfire & was got before I noticed the hiss. This hasn't solved the issue.
    Any help greatly appreciated.
    Robin
    VW Caddy 2.0 SDi 2008 BST Eng JJS Box
  2. Re: Vw Caddy 2.0 SDi misfire on cylinder 3
    Oct 2006
    Collier Street
    Update, cylinder 3 injector shot, recon 1 with associated bolts ordered, not sure if I'm doing this myself yet. Think the hiss is unrelated breather blockage.
    Robin
  1. Serious Misfire on Caddy 1.6 tdi
    By spelly 123 in forum The Commercial Range
    Last Post: 12-11-2015, 08:10 PM
  2. Misfire cylinder 3
    By michaelhare in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-04-2014, 04:50 PM
  3. A8 Misfire cylinder 6 - which is that?
    By swidds in forum A8 - S8 - V8
    Last Post: 06-05-2009, 11:44 AM
  4. Please Help Misfire on Cylinder 1
    By Pudz in forum Polo - Derby - Lupo - Fox
    Last Post: 31-05-2008, 03:46 PM
