Thread: Q7 Apple Car Play no longer working
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
  1. Re: Q7 Apple Car Play no longer working
    #21
    Nov 2015
    U.K.
    78 Post(s)
    Quote Originally Posted by andyhud007 View Post
    Hey Rob
    No worries, glad they offered to extend. Yep, mine updated after about 3 days after the phonecall to Audi CS.. so give it a couple more days. I dont think it will take 2 weeks. I know a couple of other guys have done the same 12 month extension via Audi CS and it only took a few days to "activate". Just sit tight a little longer
    RE: Red Menu. Wait for the MMI to load up and give it a couple of minutes to be fully settled down, then at the same time with both hands hold the NAV Button up and the RADIO Button downwards and hold in that position for upto 10 seconds. the screen should then change to the Red Menu.
    Pic below. Sorry its not the right way up!
    Attachment 36143
    My extended activation took over a week but that’s because it ran out just before Xmas shutdown and the folks that do it in Audi HQ in Germany were on hols for ages... It has to be done my some central department the dealers/Audi UK contact apparently.
    Q7 3.0 TDi ABT Power 325bhp MY16 S-Line Tech/Tour/Trailer packs, orca black, 21 inch 9.5J rims, rotor grey leather, sunroof, BOSE, ambient lighting, reversing cam, drivers memory seat. Gtechniq Crystal Serum Ultra ceramic coating. Sent from my iPad using Tapatalk.
    | Q7 3.0 TDi ABT Power 325bhp MY16 S-Line Tech/Tour/Trailer packs, orca black, 21 inch 9.5J rims, rotor grey leather, sunroof, BOSE, ambient lighting, reversing cam, drivers memory seat. Gtechniq Crystal Serum Ultra ceramic coating |
  2. Re: Q7 Apple Car Play no longer working
    #22
    Nov 2019
    London, UK
    I'm in a similar situation, bought a used approved audi q7 4M (2016), I can see the option for audio smartphone interface in the menu but no matter what I connect, apple or android, neither are detected for carplay/android auto. Looking at the USB ports looks like I have the right ones for this to work.
    Assume then that this is a licence/fec issue?
    Is my only route to payup for the booklet with codes to get the feature working?
  3. Re: Q7 Apple Car Play no longer working
    #23
    Feb 2016
    Hungary
    113 Post(s)
    Quote Originally Posted by sandstheman View Post
    If you see the smartphone interface, then you have it. However there are mandatory things to do:
    - you have to enable the Carplay in the Iphone menu,
    - you have to pair the phone with the Connection manager in the MMI, sometimes you have to pair it again, and you have to select it in the Connection menu. Without it, the system will not recognise the phone.
    - and most of all, you have to enable Siri, as without it, the system will not work.
    I hope these info will help to you too.
    Audi Q7/4M MY2016, 3.0 TDI/200 KW Quattro
  4. Re: Q7 Apple Car Play no longer working
    #24
    Nov 2019
    London, UK
    Have tried those steps, but still not working.
    I managed to get into the engineering menu this evening and check the FEC's and not seeing the codes that apply for apple car play/android auto. Which is odd considering the smartphone option is in the menu.
    Suspect that's the missing element then.. 😕
  5. Re: Q7 Apple Car Play no longer working
    #25
    Mar 2010
    37 Post(s)
    228 Post(s)
    Yep. That will be it. Did it definitely work before? Maybe the previous owner tried to enable the menu (Audi Smartphone Interface) which is easy to do but without the licenses it won't do anything.
    What software version is your mmi on?
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dyn Pack | Matrix | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | NightV | BOSE | DVD Chger | Homelink | Soft Doors | Heat+Snd Ins Glass | Priv Glass | Heat W/Screen | Heat Steer Wheel | Adv Key | Elec Boot Cover | Elec Steer Column | Side Assist | Air Susp | Ambient Light | Heat+Fold Mirrors | Park Assist Pack | Adv TPMS | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap | ABT Door Leds
  6. Re: Q7 Apple Car Play no longer working
    #26
    Nov 2019
    London, UK
    Quote Originally Posted by AT. View Post
    I'm assuming it worked before seeing as the menu option is there, but hasnt worked since I've had the car. So may well be the case as you that just the mneu option was enabled only.
    It's on version 0442, time for an update?
  7. Re: Q7 Apple Car Play no longer working
    #27
    Mar 2010
    37 Post(s)
    228 Post(s)
    Yes, most likely. Can you go back into your Red Engineering Menu and take a pic of your Version screen and send it over?Can see what update your eligible for.
  8. Re: Q7 Apple Car Play no longer working
    #28
    Nov 2019
    London, UK
    Sure, i'll grab a picture when I get in after work....
  9. Re: Q7 Apple Car Play no longer working
    #29
    Mar 2010
    37 Post(s)
    228 Post(s)
    Nice one.
  10. Re: Q7 Apple Car Play no longer working
    #30
    Jul 2016
    Hampshire
    44 Post(s)
    If you can get into REM (Red Engineerign Menu) you can also see which keys your car has and which are valid, this will clearly show if your car has the required keys for CarPlay/AndroidAuto
  1. Android auto/apple car play installation on RNS510
    By willc1985 in forum In Car Entertainment
    Last Post: 29-09-2019, 03:23 PM
  2. Apple Car Play Retro Fit...
    By MC09PJC in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 04-07-2019, 03:25 PM
  3. Question Apple car play retrofit
    By zurichman in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 18-01-2019, 11:29 PM
  4. Please Help Head Unit/Sat Nav/Apple Car Play
    By Adiewomersley in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 11-02-2018, 09:41 AM
  5. Apple Car Play
    By MicaBlue in forum Q7 - 4M Forum - 2016 -
    Last Post: 21-10-2017, 08:02 PM
