Thread: widow glass rattles when closing door - if the window isn't already fully closed
  1. widow glass rattles when closing door - if the window isn't already fully closed
    London
    The front passenger glass of my Golf Mk 7 rattles just once when I close the passenger door - but only if the glass is not at the fully uppermost position. I also need to close the door (very) slightly harder, to get it to close fully properly.
    These issues occurred only after the glass was smashed by a brick. The point of impact was near the top of the glass. So glass fragments went into the cabin. It seems that this caused a pivoting effect on the glass. That is, the bottom of the glass came outwards and the caused a slight outward fold in the horizontal metal trim visible on the outside of the door.
    A body shop replaced the glass promptly and appears to have fixed all visible distortions on the outside of the door. However the issues remain. What could I try next to fix the issues ?
  2. Re: widow glass rattles when closing door - if the window isn't already fully closed
    135 Post(s)
    2038 Post(s)
    This is common in this situation, it may not be correctly reassembled or a part could be broken/missing. It would have to be stripped down and the parts laid out and checked off against the parts diagram but there is not a lot to it.
  3. Re: widow glass rattles when closing door - if the window isn't already fully closed
    London
    Thank you for your rapid reply and for all your hard work on this site. I will check out what you've suggested.
  1. How to know if your heater flaps are closing fully?
    By A1EK in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-01-2017, 01:19 PM
  2. a6 se v6 rear window not closing fully?
    By Blitzskymaster in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 22-06-2014, 03:37 PM
  3. Squeeky driver's door window glass
    By noetus in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-01-2013, 09:02 PM
  4. Rattle when closing door with window down?
    By Spacer in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-04-2011, 10:11 PM
  5. A4 Cabriolet - Window not closing fully after shutting door - Ice
    By tag2312 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-01-2010, 10:13 AM
