Thread: Help - anyone in Yorkshire that can read SKC pin off ECUs?
  1. Help - anyone in Yorkshire that can read SKC pin off ECUs?
    Dec 2008
    I have picked up a 2004 a4 1.8t and from the symptoms I believe the ecu has suffered water ingress. I have a replacement and i need to get the pin or skc from the current ecu/cluster and from the donor ecu to be able to swap them over with vcds. I have tried various cables and vag eeprom programmer etc but not sure if the "no ecu found" is my laptop/cable/software or the car. So would appreciate help from someone that has a known working cable and app.. That CAN read ecu and cluster pin codes
    Beer tokens waiting..
  2. Re: Help - anyone in Yorkshire that can read SKC pin off ECUs?
    1840 Post(s)
    The 7 digit SKU no longer exists, what you want is the PIN but it is very difficult to get at unless you have full CAN Commander, the dodgy versions are very unreliable.
  1. Greetings from Yorkshire
    By jaykay81 in forum New Member Introductions
    Last Post: 15-07-2015, 10:46 AM
  2. hi from yorkshire
    By radiocodes in forum New Member Introductions
    Last Post: 27-11-2013, 12:10 PM
  3. hi from s yorkshire
    By waynea6 in forum New Member Introductions
    Last Post: 05-04-2010, 10:54 PM
