Thread: Can't connect to instrument cluster.
Results 1 to 10 of 10
  1. Can't connect to instrument cluster.
    Apr 2017
    Essex,UK
    Have a little problem with my vcds.
    Recently bought an A4 B6 1.9 TDI,connected up my vcds and everything worked.
    However,as the fuel gauge in the cluster didn't work so bought a second hand cluster and swapped over the fuel and temperature gauge.
    Now everything works in the cluster,but i can no longer connect to the instruments or even do an autoscan (can search for fault codes in everything individually except instruments though),could do both before the cluster repair.
    Any ideas of where i've screwed up ?
  2. Re: Can't connect to instrument cluster.
    1836 Post(s)
    Could you post a full scan?
  3. Re: Can't connect to instrument cluster.
    Apr 2017
    Essex,UK
    Hi Crasher,forgive my ignorance,but how do i do that ? I can't do a full auto scan if that's what you mean ?
  4. Re: Can't connect to instrument cluster.
    1836 Post(s)
    Why can't you use the chassis type specific full car scan function in VCDS?
  5. Re: Can't connect to instrument cluster.
    Apr 2017
    Essex,UK
    I don't know,it worked before i fixed the cluster.I'll give it another try later and see what it says exactly.
    Thanks for the help.
  6. Re: Can't connect to instrument cluster.
    Apr 2017
    Essex,UK
    Sorry for the delay,didn't get home until last night,work away too much...
    Just been out in the garage,couldn't get it to run a full auto scan unless i chose the chassis type manually like Crasher suggested.
    Did that and did a full scan,got a couple of fault codes with a rear door safe mode but cleared it and no more fault codes.
    However,still can't connect to the instrument cluster,everything else i can connect to.
    I know it's not exactly a massive problem as everything in the cluster works,but just curious as why this happened after i changed the fuel and temp gauge ?
  7. Re: Can't connect to instrument cluster.
    1836 Post(s)
    Temperature gauge? In the dash?
  8. Re: Can't connect to instrument cluster.
    Apr 2017
    Essex,UK
    Sorry,yes the temp gauge for coolant/engine.The old fuel gauge read full all the time so bought a second hand cluster and changed over the fuel and engine/coolant gauges.
    Everything in the cluster works fine,just can't get in to group 17 instruments ?
    Does it need coding or ?
  9. Re: Can't connect to instrument cluster.
    1836 Post(s)
    There is probaly a bad connection to the K line inside the pod.
  10. Re: Can't connect to instrument cluster.
    Apr 2017
    Essex,UK
    Ok,i'll try and take it apart again and see if there's anything obvious.
    Thanks again
  1. Question Instrument cluster Lcd
    By Nickiboy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-02-2013, 04:40 PM
  2. Instrument cluster
    By pricey01 in forum Golf MK5 - 2004 - 2009
    Last Post: 23-01-2011, 08:06 AM
  3. Help with Instrument cluster!?
    By keemaklan in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 06-03-2010, 07:42 PM
  4. Instrument cluster on the way out?
    By mrcheeezy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 08-01-2009, 12:34 PM
  5. A4 instrument cluster
    By alexf2828 in forum Audi A4 - Archive Topics
    Last Post: 24-06-2007, 10:20 PM
