Thread: Polo 9n 1.4 jatco 001 transmission problem
  1. Polo 9n 1.4 jatco 001 transmission problem
    Apr 2017
    Kuala Lumpur, Malaysia
    Hi all. My mate's 2006 polo 9n 1.4 petrol has this auto transmission problem. Doesn't go into gear when starting in the morning. Needs to warm up for around 7 minutes. Afterward it would shift perfectly fine. Tried checking the fluid and it was normal. Then gradually the problem got worse to the point that it needed 20 min of warm up time. Figure a fluid change wouldn't do harm (VW claimed this to be a lifetime fluid). Changed the filter and replaced the fluid. Warm up time got back down to 7 minutes. Googling around seems to point out that the jatco 001 transmission has some torque converter issue.
    Any thoughts?
  2. Re: Polo 9n 1.4 jatco 001 transmission problem
    1840 Post(s)
    So you can select a gear it is just that nothing happens? have you checked for fault codes and performed the basic settings.
  3. Re: Polo 9n 1.4 jatco 001 transmission problem
    Apr 2017
    Hi crasher yes exactly what you said. However it would go into gear after warming up. No fault codes whatsoever.
    An update from my mate saying that when he drove home from work today the warm up time is reduced to 3 min. Should I just let the fresh fluid to do its job? Maybe give it another change few months down the road?
  4. Re: Polo 9n 1.4 jatco 001 transmission problem
    1840 Post(s)
    I would say the ATF pump is weak. Private message me the reg and I will look into it.
  1. Replies: 0
    Last Post: 15-09-2015, 02:25 PM
  2. A6 transmission problem
    By martin86 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-01-2010, 09:44 AM
  3. Question Transmission problem
    By dnemesis2000 in forum Golf MK3 - 1993 - 1999
    Last Post: 26-06-2009, 07:19 PM
  4. Polo Transmission oil leak
    By rg1642 in forum Polo - Derby - Lupo - Fox
    Last Post: 04-05-2009, 09:24 AM
  5. 1999 Polo Transmission
    By transiberian in forum Polo - Derby - Lupo - Fox
    Last Post: 01-02-2009, 10:32 PM
