Thread: What size pipes on petrol pump?
Results 1 to 10 of 18
  1. What size pipes on petrol pump?
    Mar 2016
    Minervois, France
    37 Post(s)
    Could some kind member please tell me the sizes (inside and outside diameters) of the supply and return flexible pipes on the A4 B5 petrol pump.
    Don't force it - get a bigger hammer!
    1996 A4 B5 Avant 1.8T engine code AEB automatic with 66,000 kms - 41,000 miles on 16/09/19.
    VW T25 Camper, Alfa 33 1.4 ie, Alfa Sprint 1.5 QV, 2 Alfa 33's for parts.
  2. Re: What size pipes on petrol pump?
    Mar 2016
    Minervois, France
    37 Post(s)
    I'll answer my own question. Supply line is 7.5 mm I/D 3 mm wall thickness, so O/D is 13.5 mm.
  3. Re: What size pipes on petrol pump?
    35 Post(s)
    777 Post(s)
    Triple check the hose you use is suitable for use with E10 such as Gates Barricade if they do it in that size. The VAG part number is N 900 801 05 for the latest specification at 22.40 a meter. Only use squeeze band clamps such as N 024 122 2 or the hose can leak but Norma plate clamps are nice if you can get them.
    "I disapprove of what you say, but I will defend to the death your right to say it"
    Evelyn Beatrice Hall (1868-1956)
  4. Re: What size pipes on petrol pump?
    Mar 2016
    Minervois, France
    37 Post(s)
    Thanks, Crasher.
    Recently the car has needed to crank for several seconds before starting, and I suspected fuel pressure leaking back via the pump check/non-return valve.
    I decided that if the pump valve is leaking it would be simpler to add another check valve after the pump than to pull the pump, which is why I wanted to know the pipe size.
    In the end, not knowing how easy it is to access the pump, I made a guess and ordered an 8 mm valve, which is the correct size.
    I also have a fuel pressure test rig on order, but while waiting for this, the check valve arrived, so I decided to try it out while waiting.
    I had a suitable length of 8 mm Gates 3225 fuel hose. It is good for 10 Bar, and at least as good as the original hose in the 23-year-old car, so I used that.
    It seems to hold the pressure in the system, as the car now starts much quicker, but I will remove the check valve and do a fuel pressure test with the original setup once the test rig arrives.
    This is the check valve installation. It normally tucks down out of sight below the floor level, but I lifted it out for the picture.
  5. Re: What size pipes on petrol pump?
    Mar 2016
    Minervois, France
    37 Post(s)
    Any comments? Favourable or not, they would be appreciated.
  6. Re: What size pipes on petrol pump?
    35 Post(s)
    777 Post(s)
    Half of me says bodge and the other says nice fix, I wouldn’t do it but it is a pragmatic solution.
  7. Re: What size pipes on petrol pump?
    Mar 2016
    Minervois, France
    37 Post(s)
    Well, I wouldn't have done it for a customer, but it saves work and expense for me. I intend checking it from time to time.
  8. Re: What size pipes on petrol pump?
    35 Post(s)
    777 Post(s)
    Looking at the design of the pump, the check valve must be internal, on the earlier models it was a replaceable part on top of the pump
    http://emea.resource.bosch.com/AA/in...000/index.html
    Top marks for using plate plate clamps though, extreme gimpness
  9. Re: What size pipes on petrol pump?
    Mar 2016
    Minervois, France
    37 Post(s)
    I'd like to call adding another check valve "lateral thinking".
    My books don't mention a repairable/replaceable check valve, so I assumed I was looking at a new pump.
    I will leave the present setup until I make a pressure and delivery test, then decide on the next step.............
  10. Re: What size pipes on petrol pump?
    Mar 2016
    Minervois, France
    37 Post(s)
    I bought a Chinese made injection pressure test kit on Ebay for 47.50. It looked pretty comprehensive but turned out to cover cars only up to about 1991.
    I was about to return it, but realised that by buying a couple of adapters it could be connected satisfactorily.
    The adapters arrived today, and I tested according tom the specs in the Bentley manual. The kit connected nicely, and the operating pressures were spot on, but it didn't hold pressure after stopping the engine.
    The pressure loss was on the fuel rail side, so I removed the clip and tried to take out the fuel pressure regulator. I managed to turn it, but could not easily remove it.
    I decided not to risk damaging it without having a new one to put in, so replaced the clip and tested the leak down again.
    I must have re-seated the O-rings in the FPR, as it held 3 bar after 15 minutes, still held 2 bar after 4 hours, and just started almost immediately.
  1. Question Battery size for 2001 2L petrol 85KW AZM
    By Naseem in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-10-2017, 09:48 PM
  2. Question Injector pump O-ring size?
    By Broomhall88 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-02-2013, 09:26 PM
  3. How To Petrol pump
    By andrzej19 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-04-2012, 09:38 PM
  4. Size of petrol tank
    By GeorgeBoy in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 06-09-2009, 09:03 PM
  5. Question Petrol pump 94' Coupe
    By Norbee in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 26-01-2009, 10:27 PM
