Hi all,
Very much a newbie to VDCS but have just pulled these off my son's Leon.
Is there anything that is pointing to something significantly not right and/or what have I missed off the lengthy list of options that would be helpful?
Thanks in advance.
Andy.
PS He was told the "Neutral Gear Sensor" fault was not relevant because his car is a manual. Is this correct?
The Tyre Pressure Warning has been reset from the dashboard "calibrate" button (after manually getting them all at the correct pressures) and seems to have cleared.
Remote key 1 - Current Too Low. Just needs a new battery fitting?
Code:
Sunday,21,July,2019,10:58:05:34600
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20190529 DS308.0
Ross-Tech: Home
VIN: VSSZZZ5FZER081161 License Plate: KV14FFE
Mileage: 131682km-81823mi Repair Order:
Chassis Type: 5F-SE37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: VSSZZZ5FZER081161 Mileage: 131682km-81823miles
01-Engine -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CLHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 M HW: 04L 907 309 B
Component: R4 1,6L EDC H22 6545
Revision: 84H22---
Coding: 01110012032501090000
Shop #: WSC 00049 770 00128
ASAM Dataset: EV_ECM16TDI01104L906021M 002011
ROD: EV_ECM16TDI01104L906021P.rod
VCID: 2F3AE5AF47953EFF633-807A
1 Fault Found:
10088 - Neutral Gear Sensor
P15A1 00 [044] - Implausible Signal
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 17
Mileage: 130441 km
Date: 2019.07.12
Time: 08:30:14
Engine speed: 1232.00 /min
Normed load value: 81.2 %
Vehicle speed: 48 km/h
Coolant temperature: 69 °C
Intake air temperature: 58 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 13.100 V
Unlearning counter according OBD: 40
Neutral position sensor: current transmission angle: -13.80 °
Neutral position sensor: adapted transmission angle: -0.15 °
Transmission neutral position sensor: adaptation status-Bits 0-7: 56
Transmission neutral position sensor voltage: 1610 mV
Neutral position sensor: upper adaptation value: 3190 mV
Neutral position sensor: lower adaptation value: 1600 mV
Engaged gear: raw signal-Bits 0-7: 4
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F
Component: EMB8 EHCB H31 0356
Revision: 00000000 Serial number: 635430000009A1
Coding: 20EE8A921428096D0078060641C4240451289000608224F200410060C002
Shop #: WSC 00049 770 00101
ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
ROD: EV_Brake1UDSContiMK100ESP_033_SE37.rod
VCID: 4BC2913FD34D62DF6FB-801E
1 Fault Found:
16401 - Tire Pressure Warning
C102D 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 176
Mileage: 131567 km
Date: 2019.07.20
Time: 10:17:58
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5F0 907 426 H HW: 5F0 907 426 H
Component: AC Manuell H01 0705
Revision: 00001K07
Coding: 00100104200100001000000000001000
ASAM Dataset: EV_ACManueBHBVW37X 003017
ROD: EV_ACManueBHBVW37X_003.rod
Fresh Air Blower Front:
Geber für Kältemitteldruck/Kältemitteltemperatur:
No fault code found.
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 AC HW: 5Q0 937 084 AC
Component: BCM MQBAB M H16 0124
Serial number: 00011401300033
Coding: 0B0008424241005B0BA44000B10403081000000000000000000000000000
ASAM Dataset: EV_BCMCONTI 012001
ROD: EV_BCMBOSCH_012.rod
VCID: 79AE1BF7C951204F8D7-802C
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 5F2 955 119 HW: 5F1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 131209 041 0574
Serial number: 131212212916
Coding: 0BC5FD
Sensor For Anti Theft Alarm System:
Subsystem 2 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY133102172
Alarm horn:
Subsystem 3 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000028795075
2 Faults Found:
203016 - Unlock Switch in Rear Lid Handle
B140B 29 [008] - Signal Implausible
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 176
Mileage: 131682 km
Date: 2019.07.21
Time: 10:08:02
204290 - Remote key 1
B1479 18 [008] - Current Too Low
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 163
Mileage: 130956 km
Date: 2019.07.15
Time: 19:37:55
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 3Q0 959 655 AC HW: 3Q0 959 655 AC
Component: Airbag VW20 012 0189
Revision: -------- Serial number: 003P4P0MD3LU
Coding: 98CCC000000000005C0000CC008800000065
ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F5AF5EFD7750E7FB33-802A
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 454 001 101 14
Component: SideSensor_Df 008 0887
Serial number: 3576U000000049518E06
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 454 001 001 14
Component: SideSensor_Pf 008 0887
Serial number: 3586U000000DF9218E0S
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 454 801 601 14
Component: SideSensor_Dr 111 0148
Serial number: 3516R2DE1BD02000000C
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 454 801 601 14
Component: SideSensor_Pr 111 0148
Serial number: 3526R4148C202000000X
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 454 800 801 14
Component: FrontSensor_D 114 0149
Serial number: 3556V70299F020000008
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 507 AC HW: 5Q0 953 549
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 19011404400693
Coding: 1400
ASAM Dataset: EV_SMLSKLOMQB 009001
ROD: EV_SMLSKLOMQB_020_VW37.rod
VCID: 77AA1DCFFF45363FFB3-8022
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5F0 920 961 H HW: 5F0 920 961 H
Component: KOMBI 203 2210
Coding: 27A402002180260001082A00000000
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_008_VW26.rod
VCID: 2E04F8AB409F37F7685-807A
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 P HW: 5Q0 907 530 E
Component: GW MQB Mid 124 1164
Revision: -------- Serial number: 0001384772
Coding: 030100F40B087300EF000048080F00010001000000000000000000000000
ASAM Dataset: EV_GatewLear 010015
ROD: EV_GatewLear_010.rod
VCID: 3E24C8EB90FFC777F85-806A
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 5F0 959 537 B HW: 5F0 959 537 B
Component: E221__MFL-PR6 H03 0120
Serial number: 000000000A0055161213
Coding: 002000
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 4539941903
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q4 959 593 B HW: 5Q4 959 593 B
Component: TSG FS 009 0014
Serial number: 0000088332083
Coding: 00100220C001040000001000
ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 44D0BA03FE13ADA7AE1-8010
Drivers Door Rear Control Module:
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 005 0005
Serial number: 00000000000001489767
Coding: 2D0000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 0103
ASAM Dataset: EV_SteerAssisMQB 010031
ROD: EV_SteerAssisMQB_010.rod
VCID: 41DEB317E101B88F857-8014
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q4 959 592 B HW: 5Q4 959 592 B
Component: TSG BFS 009 0014
Serial number: 0000087591953
ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 43D2B91FFB1DAA9F97B-8016
Passengers Rear Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 005 0005
Serial number: 00000000000001435071
Coding: 350000
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 5F0 035 869 A HW: 5F0 035 869 A
Component: MU-E--ER 635 5800
Serial number: 11091300010557
Coding: 04730000BE00000011110001000000002F0004860000010000
ASAM Dataset: EV_MUEnt4CLGE 001025
ROD: EV_MUEnt4CLGE_VW26.rod
VCID: 2B02F1BF738D42DF4FB-807E
End----------(Elapsed Time: 01:00, VBatt start/end: 12.3V/12.3V)-----------
Sunday,21,July,2019,11:00:59:34600
Ross-Tech: Home
Mode 01 - PID 01 : Readiness -- Address 7E8
Number of DTCs stored: 0 -- MIL Status: MIL OFF
Misfire monitoring: Not installed.
Fuel System: Passed
Comprehensive Components: Passed
Catalyst monitoring: Not installed.
Heated catalyst monitoring: Not installed.
Evaporative system monitoring: Not installed.
Secondary air system monitoring: Passed
A/C system refrigerant monitoring: Not installed.
Oxygen sensor monitoring: Passed
Oxygen sensor heater monitoring: Passed
Exhaust Gas Recirculation: Passed
Mode 03: Emission related fault codes
Address 7E8: No fault code found.
Mode 9 : Calibration Identification
Type 02 - VIN : VSSZZZ5FZER081161 (Address E8)
Type 04 - Calibration ID : 04L021M 6545BDBD (Address E8)
Type 06 - Calibration Verification Number : 8FF5EE53 (Address E8)
Type 0A - Controller Name : ECM-EngineControl (Address E8)
Type 0B - In-use performance tracking :
OBD Monitoring Conditions Encountered count : 1965
Ignition cycle count : 10102
Conditions completion count / Specified conditions encountered count
NMHC Catalyst : 0 / 0
NOx/SCR Catalyst : 0 / 0
NOx Adsorber : 0 / 0
PM Filter : 3650 / 164
Exhaust Gas Sensor : 4154 / 1965
EGR and/or VVT : 8819 / 1965
Boost Pressure : 0 / 0
Fuel : 0 / 0
Sunday,21,July,2019,11:07:12
VCDS Release 19.6.1 (x64): Generic OBD2
Mode 1:Read Data
04:Calculated load value 23.1 %
34:Bank 1 Sensor 1 Status 0.279 Lambda -0.004 mA
69:EGR Command/Actual/Error EGR A:---/---/--- % EGR B:18/17/-2 %Sunday,21,July,2019,11:09:11:34600
Ross-Tech: Home
Address 01: Engine Labels: 04L-907-309-V1.clb
Control Module Part Number: 04L 906 021 M HW: 04L 907 309 B
Component and/or Version: R4 1,6L EDC H22 6545
Software Coding: 01110012032501090000
Work Shop Code: WSC 00049 770 00128
ASAM Dataset: EV_ECM16TDI01104L906021M 002011 (SE37)
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 17
Mileage: 130441 km
Date: 2019.07.12
Time: 08:30:14
Readiness Status: 00000000 00001110 11101000 00000000
MIL Status: MIL OFF
Fuel System: Passed
Number of EOBD-related DTC(s): 0
Address 01: Engine (04L 906 021 M)
11:13:12
IDE00430-ENG57549 Particle filter: field regeneration request status-Bits 0-7 0
IDE00431-ENG57549 Particle filter: field regeneration lock status-Bits 0-7 0
IDE00432 Particle filter: time since last regeneration 9420 s
IDE00433 Particle filter: oil ash volume 0.07 l
IDE00434 Particle filter: soot mass calculated 13.36 g
IDE00435 Particle filter: soot mass measured 0.95 g
IDE00436 Particle filter: kilometers since last regeneration 205478 m
IDE01259 EGR Solen.val.: actual value 100.00 %
IDE03034 Actual value of low pressure EGR valve 78.27 %
IDE03383 Exhaust mass flow of EGR 0.0 kg/h
