i have recently noticed a screeching sound emitting from drivers side.
today the low coolant level light came on and there was coolant on the ground.
i have removed the front drivers side wheel and the wheel arch liner and discover the leak around water pump and nothing above.
is this likely to be anything else or is it a failed water pump?
i was due to have the timing belt and water pump done this month in any case.
any suggestions
