Thread: Crankshaft sensor location
  1. Crankshaft sensor location
    Jul 2019
    Oxford
    Hi first time posting
    2007 4.2tdi v8 looking for info on replacing the crankshaft sensor/location
    any help would be appreciated
  2. Re: Crankshaft sensor location
    1840 Post(s)
    The G28? You have a fault code for this?
  3. Re: Crankshaft sensor location
    Jul 2019
    Oxford
    No fault codes apart from glow plug 7 which has been changed
    Car was ticking over and then cut out,now will not start.
    Read various threads about this and people start with fuses relays fueling system,but they all had codes
    Car will turn over strong and fast all dash lights work no immobiliser light or engine fault light
    Thought I’d start with what they ended up changing last after they spent a fortune on relays and fuel pumps to no avail.
  4. Re: Crankshaft sensor location
    1840 Post(s)
    Do you have VCDS? This will be the BTR engine I think? The engine speed sensor for these is 077 905 381 K which are £115.62 from Audi.
    The sensor is under the car bolted into the gearbox a 6 o'clock just aft of the steering rack, very easy with it lifted up.
  1. location of G28 crankshaft or speed sensor on Golf 4, 2002, 1.6 FSI
    By dboyr666 in forum Golf MK4 - 1999 - 2004
    Last Post: 18-03-2013, 11:01 AM
  2. Replies: 1
    Last Post: 03-11-2012, 02:41 PM
  3. Crankshaft Position Sensor Location (Error code P0322)
    By Harv91 in forum Polo - Derby - Lupo - Fox
    Last Post: 06-05-2012, 08:19 AM
  4. crankshaft position sensor location
    By collym3 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-04-2010, 01:32 PM
  5. 2.5tdi v6 crankshaft locking pin location
    By The Fiend in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-12-2009, 11:13 PM
