Thread: Oil pressure warning light - STOP! : 1.9 tdi PD
Results 1 to 9 of 9
  1. Oil pressure warning light - STOP! : 1.9 tdi PD
    Sep 2017
    Tyrone
    This light is intermittent on my 1.9 Tdi pd 105. When stopped and started it goes off, but after driving it will come on once briefly - Then go off, then come back on but wont go off until the car is stopped and started. It sounds really sweet running and is done under 100k miles
    The car has got a 2nd hand turbo fitted (working perfect)
    At the time of fitting the sump was also removed and cleaned out along with the pickup pipe
    Oil and filter changed
    New oil sensor beside filter fitted
    What else could this be? As I need to get it sorted ASAP!
  2. Re: Oil pressure warning light - STOP! : 1.9 tdi PD
    1837 Post(s)
    Was the problem there before all the work or did it appear after?
  3. Re: Oil pressure warning light - STOP! : 1.9 tdi PD
    Sep 2017
    Tyrone
    The car was bought with a 'whiney' turbo as part of a trade in. This light was on at that time also.
  4. Re: Oil pressure warning light - STOP! : 1.9 tdi PD
    1837 Post(s)
    You should have a proper hot oil pressure test done. Do you know exactly which oil pressure switch was fitted?
  5. Re: Oil pressure warning light - STOP! : 1.9 tdi PD
    Sep 2017
    Tyrone
    Do you mean as in brand of oil pressure switch? It probably was just from my local motorfactors, I would contact my mechanic but I know hes on holidays atm.
    I might add the car does not put out any smoke, no leaks, and the level remains the same. Like I say the engine also sounds really sweet!
  6. Re: Oil pressure warning light - STOP! : 1.9 tdi PD
    1837 Post(s)
    There are a number of different switches used with very specific operating ranges and just a tiny difference can cause the alarm to go off as it is a dynamic system rather than the old fashioned low pressure makes contact idea, that went out with VAG in the early 80’s with an excellent twin switch dynamic system but when the Golf 4 came along they cheapened the system by using one switch finely tuned to detect problems so fit a 1.2>1.6 Bar switch where you should have a 0.55>0.85 Bar (they have the same thread and connection), then you are going to have issues.
  7. Re: Oil pressure warning light - STOP! : 1.9 tdi PD
    Oct 2017
    London
    12 Post(s)
    Dont always assume the part number you remove is the correct number to replace the item with. Crasher spotted someone previously had fitted a petrol oil pressure switch to a diesel golf I had with a switch failure. As already said get a oil pressure test done to make sure you have good oil pressure.
  8. Re: Oil pressure warning light - STOP! : 1.9 tdi PD
    1837 Post(s)
    That was odd, 7.23pm and I still sound lucid....
  9. Re: Oil pressure warning light - STOP! : 1.9 tdi PD
    Jul 2019
    DMcCo, have you made the oil pressure test yet?
  1. Question Oil pressure warning stop! immediately 1.9tdi
    By Callum53 in forum Jetta MK3 - 2005 - 2013
    Last Post: 07-04-2018, 08:44 AM
  2. Please Help Stop engine/oil pressure warning light comes on
    By GnasheRRR in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-10-2011, 11:05 AM
  3. STOP! engine oil pressure warning
    By del_boy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-11-2008, 03:19 PM
  4. Engine Oil Pressure Warning (STOP) - please help
    By Nedx in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-10-2008, 10:41 PM
  5. STOP ! Low Oil Pressure Warning
    By Tnarg in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-01-2008, 11:33 AM
