Thread: Windscreen washers
  1. Windscreen washers
    Mar 2019
    Hertfordshire, UK
    Hi, Having a blocked windscreen washer jet, I removed the jet pack from under the bonnet to give my pin better access.
    What is the electrical connection for?
    Is it some sort of one way valve? Cant think of anything else.
    2014 Audi A4 Avant S Line AWD Blue 45k miles plus several Jags.
  2. Re: Windscreen washers
    1837 Post(s)
    Some washer jets are heated.
  3. Re: Windscreen washers
    Mar 2019
    Hertfordshire, UK
    Well I never thought of that! I did consider that they could have a tiny motor that aimed the jets higher the faster the car went though! 😂😂😂😂
    Thank you for your reply. Like it.
  4. Re: Windscreen washers
    1837 Post(s)
    It used to be much more common on VAG cars, the Golf 2 GTI had them almost right through production but they seemed to fade away.
    By wedgie7 in forum Audi A3 - 8V - 2012 - 2016
    Last Post: 15-04-2018, 07:35 PM
  2. Windscreen washers.
    By dvd8n in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 10-02-2014, 02:55 PM
  3. Heated windscreen washers
    By charlescampion in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-10-2011, 10:32 PM
  4. windscreen washers not working
    By borakev in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-12-2010, 09:14 PM
  5. windscreen washers
    By predatoress in forum TT - 8N Forum - 1998 - 2006
    Last Post: 27-06-2009, 09:12 PM
