Thread: ABS on, Brake flashing, no A/C, no Speedometer etc...
  1. ABS on, Brake flashing, no A/C, no Speedometer etc...
    Jul 2019
    Zvolen, Slovakia
    Hello there,
    After having an A/C compressor replaced I have multiple warnings from the car. The ABS light is solid, Brake light is flashing, Speedometer stopped working (might be because of the ABS) and the A/C is not working. I've tried to read the fault codes with a simple VAG-COM from ebay and got all the codes below. The ABS controller would not communicate. I have no idea what caused this but it was all working fine before. It seems like an electrical fault to me but to be honest I don't really understand this that much. Anyone had a same problem or knows how to deal with this, please?
    Audi A4 B6 Avant, 2003, 2.5 TDI, multitronic
    VAG-COM
    Windows Based VAG/VAS Emulator
    Version: Release 409.1-S
    Ross-Tech: Home
    Dealer/Shop Name:
    Workshop Code: 000 00000
    Self-Diagnosis Log
    Tuesday, 09 July 2019, 17:38:26
    VIN Number: WAUZZZ8E83A276665 License Plate: PE170BL
    Mileage: 205584 Repair Order:
    Chassis Type: 8E - Audi A4 B6
    Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
    Address 01: Engine
    Controller: 8E0 907 401 Q
    Component: 2.5l V6 TDI 0000AG 0014
    Coding: 02017
    Shop #: WSC 63351
    00006059 130 106JC150_1.V79874887292
    2 Faults Found:
    18062 - Please check DTC Memory of Instrument Cluster
    P1654 - 35-00 - -
    18057 - Shareware Version. To Decode all DTCs
    P1649 - 35-00 - Please Register/Activate
    Readiness: N/A
    Address 02: Auto Trans
    Controller: 8E2 910 155 F
    Component: V30 01J 2.5lTDI RdW 3040
    Coding: 00001
    Shop #: WSC 44556
    3 Faults Found:
    18259 - Powertrain Data Bus: Missing Message from ABS Controller
    P1851 - 35-00 - -
    18165 - Shareware Version. To Decode all DTCs
    P1757 - 35-10 - Please Register/Activate - Intermittent
    18258 - Shareware Version. To Decode all DTCs
    P1850 - 35-10 - Please Register/Activate - Intermittent
    Address 08: Auto HVAC
    Controller: 8E0 820 043 J
    Component: A4 Klimaautomat 1116
    Coding: 00000
    Shop #: WSC 63351
    3 Faults Found:
    01810 - Actuating Motor for Temperature Flap: Right (V159)
    41-10 - Blocked or No Voltage - Intermittent
    01274 - Shareware Version. To Decode all DTCs
    41-10 - Please Register/Activate - Intermittent
    01312 - Shareware Version. To Decode all DTCs
    79-00 - Please Register/Activate
  2. Re: ABS on, Brake flashing, no A/C, no Speedometer etc...
    108 Post(s)
    1816 Post(s)
    You need a proper VCDS dongle, no one has the time or patience to interpret all those shareware codes for you.
  3. Re: ABS on, Brake flashing, no A/C, no Speedometer etc...
    Jul 2019
    Zvolen, Slovakia
    Sorry, I am really new to this. This is what I found on the internet.
    VAG-COM
    Ross-Tech: Home
    Dealer/Shop Name:
    Self-Diagnosis Log
    Address 01: Engine
    Coding: 02017
    Shop #: WSC 63351
    2 Faults Found:
    P1654 - 35-00 - -
    18057 - Powertrain Data Bus: Missing message from ABS Controller
    P1649 - 35-00 -
    Coding: 00001
    Shop #: WSC 44556
    3 Faults Found:
    P1851 - 35-00 - -
    18165 - Supply Voltage: Open Circuit
    P1757 - 35-10 - Intermittent
    18258 - Powertrain Data Bus: Missing Message from ECU
    P1850 - 35-10 - Intermittent
    Coding: 00000
    Shop #: WSC 63351
    3 Faults Found:
    01274 - Air Flow Flap Positioning Motor (v71)
    01312 - Powertrain Data Bus
    79-00 – Please check fault codes
  4. Re: ABS on, Brake flashing, no A/C, no Speedometer etc...
    108 Post(s)
    1816 Post(s)
    First of all you need to obtain a proper VCDS (VAG-COM) cable with version 19.6.1 loaded on your lap top Ross-Tech: VCDS: Downloads: Current Release and Manual
    Do a full vehicle scan and post the results.
  5. Re: ABS on, Brake flashing, no A/C, no Speedometer etc...
    Jul 2019
    Zvolen, Slovakia
    At the end it was just a 10A ESP fuse. Sorry for spamming the forum
  6. Re: ABS on, Brake flashing, no A/C, no Speedometer etc...
    108 Post(s)
    1816 Post(s)
    You didn’t spam anything. Do you know which fuse number it was, there may be an underlying problem.
  7. Re: ABS on, Brake flashing, no A/C, no Speedometer etc...
    Jul 2019
    Zvolen, Slovakia
    Sorry, I wasn't around for a long time
    It was number 7 fuse (Electronic Stability Program ESP)
  1. Please Help audi a6 parking brake flashing
    By AigarsH in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-12-2018, 07:50 PM
  2. Flashing brake lights
    By gdallas in forum VCDS - General Questions
    Last Post: 09-03-2014, 06:20 PM
  3. Emergency Brake Flashing Lights
    By royclark in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-09-2013, 11:21 AM
  4. asr abs on. brake warning flashing
    By sjcelliot in forum Golf MK4 - 1999 - 2004
    Last Post: 09-12-2008, 05:41 PM
  5. ABS and brake warning light flashing
    By Leon Fletcher in forum VCDS - General Questions
    Last Post: 31-07-2008, 01:27 PM
