Thread: chattering noise and fast loss of coolant
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. Re: chattering noise and fast loss of coolant
    1840 Post(s)
    You have the wrong kit.
  2. Re: chattering noise and fast loss of coolant
    Jun 2006
    6 Post(s)
    OK you say I have the wrong kit - shall I give you the chassis number for cross referencing?.
    When I turn the crank twice to check the tensioner pointer the pointer can be seen to be moving through about 8mm. Given that we had a water pump pulley partially break up could this in the process have bent the camshaft?. The crank gear was replaced by me as the original was damaged when the water pump broke. Any thoughts Crasher?
  1. Replies: 3
    Last Post: 24-08-2015, 12:50 PM
  2. Please Help Chattering noise when heater is switched on?
    By warrtydog in forum Golf MK4 - 1999 - 2004
    Last Post: 25-07-2010, 11:01 AM
  3. Rattling/Chattering Noise from Clutch
    By OILBURNER1976 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-01-2010, 10:55 PM
  4. Please Help Intermittent Chattering noise??
    By SEMKY in forum Audi A3 - Archive Topics
    Last Post: 27-06-2008, 01:52 PM
  5. Jetta Fast extreme coolant leak
    By truckerock in forum Archive posts
    Last Post: 28-12-2007, 01:21 AM
