Thread: Multiple fault code and errors full read out
  1. Multiple fault code and errors full read out
    Jan 2010
    walsall
    Good afternoon ladies and gents, needed some advice and guidance how to trouble shoot the multiple errors I'm getting i think they all point to the cluster?? or there is probably one central point where all these go thru like a relay that is the issue can someone advice ?
    Thursday,04,July,2019,21:42:45:05031
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 15.7.1.0 (x64)
    Data version: 20150904
    Ross-Tech: Home
    VIN: WVWZZZ3CZA****** License Plate:
    Mileage: 134120km-83338mi Repair Order:
    Chassis Type: 3C (3C0)
    Scan: 01 02 03 08 09 10 14 15 16 17 19 25 37 42 44 46 52 53 56 62
    72 77
    VIN: WVWZZZ3CZA****** Mileage: 134120km-83338miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: Malfunction 0010
    14-Susp. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: Sporadic communication error 1000
    37-Navigation -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    77-Telephone -- Status: OK 0000
    Address 01: Engine (CBB) Labels: 03L-906-022-CBA.clb
    Part No SW: 03L 906 022 QG HW: 03L 907 309
    Component: R4 2,0L EDC G000AG 3736
    Revision: 13H02--- Serial number: VWZCZ000000000
    Coding: 0000078
    Shop #: WSC 00784 210 81923
    VCID: 7AFC6AC735CCFEEE13-802E
    1 Fault Found:
    049493 - No Communication with Instrument Cluster
    U0155 - 000 - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 6
    Fault Frequency: 3
    Reset counter: 255
    Mileage: 137513 km
    Time Indication: 0
    Date: 2013.11.10
    Time: 00:00:07
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Temperature: 21.6°C
    Voltage: 11.86 V
    Bin. Bits: 00000000
    Torque: 93.0 Nm
    Temperature: 34.2°C
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 02E-927-770.lbl
    Part No SW: 02E 300 051 T HW: 02E 927 770 AJ
    Component: GSG DSG AG6 440 1912
    Revision: 04844002 Serial number: 00000905170423
    Coding: 0000020
    Shop #: WSC 05311 000 00000
    VCID: 244074BFE7C8581E19-8070
    2 Faults Found:
    18270 - Powertrain Data Bus
    P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 255
    Reset counter: 13
    Mileage: 137513 km
    Time Indication: 0
    Date: 2013.11.10
    Time: 00:00:07
    18082 - Powertrain Data Bus
    P1674 - 000 - Implausible Message from Instrument Cluster - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Reset counter: 13
    Mileage: 137513 km
    Time Indication: 0
    Date: 2013.11.10
    Time: 00:00:07
    Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
    Part No SW: 3C0 614 109 AF HW: 3C0 614 109 AF
    Component: J104 C4 440 V2 0015
    Revision: --025--- Serial number: 00000795274485
    Coding: 0003368
    VCID: 62CC32A7BD5C162E2B-8036
    1 Fault Found:
    01317 - Control Module in Instrument Cluster (J285)
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 69
    Mileage: 137513 km
    Time Indication: 0
    Date: 2013.11.10
    Time: 00:00:07
    Freeze Frame:
    Speed: 0.0 km/h
    Hex Value: 0x0000
    Voltage: 11.75 V
    Bin. Bits: 00011111
    Count: 152
    Hex Value: 0x0000
    Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
    Part No SW: 5K0 907 044 BD HW: 5K0 907 044 BD
    Component: Climatronic H14 0608
    Revision: 00003001
    Coding: 0000000000
    Shop #: WSC 05311 115 00000
    ASAM Dataset: EV_Cliamtronic A01001
    ROD: N/A
    VCID: 6ED45697B184A24EBF-803A
    No ASAM data for: "EV_Cliamtronic" (VW36 *)
    1 Fault Found:
    13701456 - ROD - Unknown Error Code
    - 00 [008]
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 69
    Date: 2019.06.20
    Time: 00:00:06
    Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
    Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
    Component: Bordnetz-SG H54 2602
    Revision: 00H54000 Serial number: 00000009667662
    Coding: E1808F8B00041A0047970F00170000000008FF475C40017C17 0000000000
    Shop #: WSC 05124 000 00000
    VCID: 336287E35226CFA690-8066
    Subsystem 1 - Part No: 3C8 955 119 A Labels: 1KX-955-119.CLB
    Component: Wischer 230409 022 0602
    Coding: 00046997
    Shop #: WSC 05124
    Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 240609 054 0402
    Coding: 00209133
    Shop #: WSC 05124
    4 Faults Found:
    00985 - Right Tail Light (M2)
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 72
    Mileage: 137511 km
    Time Indication: 0
    Freeze Frame:
    ON
    Voltage: 12.20 V
    ON
    ON
    OFF
    OFF
    ON
    00979 - Lamp for Low Beam; Right (M31)
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 72
    Mileage: 135517 km
    Time Indication: 0
    Freeze Frame:
    ON
    Voltage: 13.35 V
    ON
    ON
    OFF
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 69
    Mileage: 137513 km
    Time Indication: 0
    Freeze Frame:
    ON
    Voltage: 11.80 V
    ON
    ON
    OFF
    OFF
    OFF
    02235 - Stationary Cornering Lamp (Left) (M51)
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 56
    Mileage: 136364 km
    Time Indication: 0
    Freeze Frame:
    ON
    Voltage: 11.45 V
    ON
    ON
    OFF
    OFF
    ON
    Address 10: Park/Steer Assist
    Cannot be reached
    Address 14: Susp. Elect. (J250) Labels: None
    Part No SW: 3C0 907 376 A HW: 3C0 907 376
    Component: DAEMPFUNGS-SG H07 0070
    Revision: 00000000 Serial number: 15060904690001
    Coding: 010180
    Shop #: WSC 05311 000 08193
    VCID: 275A63B356FEB3063C-8072
    2 Faults Found:
    03262 - Comfort Restriction
    000 - - - Intermittent
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 46
    Reset counter: 94
    Mileage: 131816 km
    Time Indication: 0
    Date: 2013.07.31
    Time: 20:38:01
    Freeze Frame:
    Error Code: 2
    Bin. Bits: 00000000
    00774 - Level Control System Sensor; Rear Left (G76)
    003 - Mechanical Failure - Intermittent
    Freeze Frame:
    Fault Status: 00100011
    Fault Priority: 2
    Fault Frequency: 46
    Reset counter: 94
    Mileage: 131816 km
    Time Indication: 0
    Date: 2013.07.31
    Time: 20:38:01
    Freeze Frame:
    Bin. Bits: 00000001 00000000
    Bin. Bits: 00000000 00000000
    Address 15: Airbags Labels: 5N0-959-655.lbl
    Part No SW: 5N0 959 655 J HW: 5N0 959 655 J
    Component: J234__301 VW10 HI 1916
    Revision: 20013000 Serial number: 003E2PBL4TE.
    Coding: 0012337
    VCID: 4480D43F0788781E39-8010
    Subsystem 1 - Serial number: 6332MTS610131379
    Subsystem 2 - Serial number: 6342MTS611661499
    Subsystem 3 - Serial number: 6351HTS67R6426KJ
    Subsystem 4 - Serial number: 6361HTS6QKA126KJ
    Subsystem 5 - Serial number: 00000000000000000
    Subsystem 6 - Serial number: 00000000000000000
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 69
    Mileage: 137513 km
    Time Indication: 0
    Date: 2013.11.10
    Time: 00:00:07
    Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
    Part No SW: 3C0 953 549 AJ HW: 3C0 953 549 AJ
    Component: J0527 0030
    Revision: 00032000 Serial number: 3C5953507BN
    Coding: 0001711
    VCID: 74E044FF17A8889E49-8020
    Subsystem 1 - Part No: 3C8 959 537 B
    Component: E221__MFL-TAP H4ÿ 0021
    Coding: 00000226
    Shop #: WSC 00000
    1 Fault Found:
    01426 - Controls in Steering Wheel (E221)
    Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
    Part No SW: 3C8 920 970 HX HW: 3C8 920 970 HX
    Component: KOMBI H02 0206
    Coding: 440F00
    Shop #: WSC 19500 000 1048576
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
    ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
    VCID: 091E050BA82AE5760A-805C
    No fault code found.
    Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb
    Part No SW: 3C0 907 530 L HW: 3C0 907 951
    Component: J533__Gateway H13 0152
    Revision: H13 Serial number: 3300P0961905DE
    Coding: FDA87F06400602009003
    Shop #: WSC 05314 000 00000
    VCID: 2A5C9A8785EC8E6E23-807E
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 69
    Time Indication: 0
    Address 25: Immobilizer Labels: 3C0-959-433-25.clb
    Part No SW: 3C0 959 433 AR HW: 3C0 959 433 AR
    Component: IMMO 043 0383
    Revision: 00043000 Serial number: VWZCZ000000000
    Shop #: WSC 131071 1023 2097151
    Subsystem 1 - Part No: 3C0 905 861 G
    Component: ELV 027 0380
    3C0905861G ELV 027 0380
    Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
    Part No SW: 1T0 035 680 D HW: 1T0 035 680 B
    Component: RNS-MID H11 3810
    Revision: AB001001 Serial number: VWZ6Z7J6169087
    Coding: 04000400040000A20000
    VCID: 2F6A8B937E0EEB46F4-807A
    1 Fault Found:
    00862 - Antenna for GPS Navigation (R50/R52)
    007 - Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 96
    Mileage: 138113 km
    Time Indication: 0
    Date: 2013.07.07
    Time: 18:17:57
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
    Part No SW: 1T0 959 701 L HW: 1K0 959 793 P
    Component: J386 TUER-SG FT 1534
    Revision: 71009005 Serial number: 00000884798617
    Coding: 0000693
    VCID: 4088D82F1390643E1D-8014
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 H
    Component: EPS_ZFLS Kl. 209 2901
    Revision: 00H15000
    Shop #: WSC 02069 000 90108
    VCID: 2F6A8B93BE0EEB46F4-807A
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 69
    Mileage: 137513 km
    Time Indication: 0
    Date: 2013.11.10
    Time: 00:00:07
    Freeze Frame:
    Voltage: 12.00 V
    DD
    Temperature: 47.0°C
    RPM: 0 /min
    Speed: 0.0 km/h
    Speed: 0.0 km/h
    Count: 0
    Address 46: Central Conv. Labels: 3C0-959-433-46.clb
    Component: KSG PQ46 ELV 043 0612
    Coding: 01910A0001860E76360494157008DFCE107801
    Subsystem 1 - Part No: 1K8 951 605
    Component: LIN BACKUP HORN H09 9002
    Subsystem 2 - Part No: 3C0 951 171 C
    Component: Neigungssensor 004 0611
    Subsystem 3 - Part No: 3C0 951 171 C
    Component: Innenraumueberw.004 0611
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
    Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
    Component: J387 TUER-SG BT 1534
    Revision: 71009005 Serial number: 00000756798618
    Coding: 0000692
    VCID: 418EDD2B189A6D3612-8014
    Address 53: Parking Brake Labels: 5N0-907-801.clb
    Part No SW: 3C8 907 801 C HW: 3C8 907 801 C
    Component: J540 EPB3 VW-13618 0005
    Revision: 010 Serial number: 00000000032461
    Coding: 0000057
    1 Fault Found:
    01316 - ABS Control Module
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 69
    Mileage: 137513 km
    Time Indication: 0
    Date: 2013.11.10
    Time: 00:00:07
    Freeze Frame:
    Voltage: 11.60 V
    Count: 111
    Speed: 0.0 km/h
    Hex Value: 0x1261
    Hex Value: 0x0001
    Hex Value: 0x1010
    Address 56: Radio (J0506) Labels: 1T0-035-680.clb
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 96
    Mileage: 138113 km
    Time Indication: 0
    Date: 2013.07.07
    Time: 18:17:57
    03138 - Input AUX IN
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 56
    Mileage: 134124 km
    Time Indication: 0
    Date: 2013.11.24
    Time: 21:39:39
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 3C8 959 703 B HW: 1K0 959 795 Q
    Component: J388 TUER-SG HL 0309
    Revision: 43004101 Serial number: 00000000952387
    Coding: 0000144
    VCID: 316E8DEBA83AFDB6E2-8064
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 3C8 959 704 B HW: 1K0 959 794 Q
    Component: J388 TUER-SG HR 0309
    Revision: 43004101 Serial number: 00000000960357
    Coding: 0000144
    VCID: 326C82E7AD3CC6AE9B-8066
    Address 77: Telephone Labels: RETROFIT77.lbl
    Part No SW: KTC 364 96P HW: KTC 364 96P
    Component: SWP:3.23.5 H24 0210
    Revision: 00000000 Serial number: 00000000000000
    Shop #: WSC 21977 142 74100
    VCID: 3E74A6D7696412CE6F-806A
    End-------------------------(Elapsed Time: 03:03)--------------------------
  2. Re: Multiple fault code and errors full read out
    1840 Post(s)
    Put the battery on charge, clear all the codes and do a non running code read making sure the battery is over 12v and if it will start, a running code read. Post those and use the [code] [code/] function which makes the post more compact and easier to read.
    One point, the copy of VCDS you are using is years out of date and commonly one seen with fake VCDS cables.
  3. Re: Multiple fault code and errors full read out
    Jan 2010
    walsall
    “non running code read ”
    Can u explain this in more detail ?
  4. Re: Multiple fault code and errors full read out
    Jan 2010
    walsall
    “use the [code] [code/] function which makes the post more compact and easier to read.”
    Sorry I'm a kinda new user to this forum can u explain how to do the above also.
  5. Re: Multiple fault code and errors full read out
    1840 Post(s)
    By non running I mean ignition on engine not running and then when running. There is a feature you can use to post a code read in a scrolling box but having never used it I am not sure more than using the [code] [code/] function
  6. Re: Multiple fault code and errors full read out
    Jan 2010
    walsall
    Thanks I will try that.
    Also I forgot to state the car has never had a flat battery scene the last codes were cleared.
  7. Re: Multiple fault code and errors full read out
    1840 Post(s)
    Some of the controller tie/date stamps are out (nothing unusual) but some controllers showed a voltage of less than 12v or less when the main fault occurred, when using the dealer system ODIS the current battery voltage is always displayed on the screen and if it goes below 12v it turns red and gets upset.
  1. Multiple errors- TMPS, ABS, ESP, PARKING BRAKE
    By bubak_here in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 07-09-2018, 01:33 PM
  2. Help request: Reading RG31 - Fault code read on 2012 A6
    By 5678 in forum VCDS - Help Requests
    Last Post: 10-06-2013, 04:30 PM
  3. Fault Code Read Needed - Golf Mk3 1.6 AEE
    By SammoVWT in forum VCDS - Users Locations
    Last Post: 05-03-2010, 09:53 AM
  4. Fault code read needed - Polo 1.4FSI, Wigan
    By batteryman in forum VCDS - Users Locations
    Last Post: 04-03-2010, 06:44 PM
  5. Vagcom Fault Code Read Needed
    By Rubens in forum VCDS - General Questions
    Last Post: 19-10-2008, 09:40 AM
