Thread: Multitronic Oil Change - More fluid out than in?
  1. Multitronic Oil Change - More fluid out than in?
    2003 Audi A6 1.9 TDI with 260K
    Ok I've always got the Audi main dealer to do previous gearbox oil changes, but decided to do this one myself.
    Before I drained the oil I ran the gearbox oil to about 80Deg C and then dropped the inspection plug (expecting a few ml to come out due to thermal expansion) but about 700 ml came out????
    I followed the instructions for refilling all went fine but in total about 700ml more came out than went in? Ive tried topping up twice with the car level and oil at 35deg C etc due to make sure the pump is primed but its still about 500 ml short of what came out??
    I can only assume it was overfilled by Audi at the last change - unless the oil expands over time?
    Thoughts - Have I missed something - the car drives fine?
  2. Re: Multitronic Oil Change - More fluid out than in?
    1837 Post(s)
    The oil is synthetic and expands considerably with temperature which is why the 30 to 40 degree window is so important. We always level set at 30 so you doing it at 35 and basing your measuring on an 80 degree drain would easily account for the difference.
  3. Re: Multitronic Oil Change - More fluid out than in?
    Ok thanks Crasher, is it worth me topping up using 30deg as I have some spare fluid?
  4. Re: Multitronic Oil Change - More fluid out than in?
    1837 Post(s)
    I would just do a 30 level plug drop, if little comes out, add some, let it drain and seal. You can’t be too obsessive or you will end up bent, burnt out and destroyed like me.
  5. Re: Multitronic Oil Change - More fluid out than in?
    Jul 2008
    Hi - I know this thread is two years old but I'm curious to know whether you resolved the CVT fluid level issue? I have been working on my multitronic and around 700ml less went back in after replacing TCU.
    Regards..
  1. ATF Fluid change help
    By Onefut in forum Polo - Derby - Lupo - Fox
    Last Post: 07-01-2016, 09:56 AM
  2. Question What fluid can be used for Multitronic?
    By Nick Maingot in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-08-2014, 06:04 AM
  3. Please Help Brake Fluid Change Is It A Must?
    By rapport25 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-04-2012, 06:55 AM
  4. ATF fluid change for A4 TDI
    By MarkEd in forum New Member Introductions
    Last Post: 14-06-2010, 10:32 PM
  5. brake fluid change
    By shuggie in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-07-2008, 04:51 PM
