Thread: 3.0 v6 petrol cambelt change - quick check
  1. 3.0 v6 petrol cambelt change - quick check
    Liverpool
    11 Post(s)
    Right, going to book the 3.0 v6 (been debating it for a while) into a local specialist for a cambelt and water pump change this month, anytihng i should ask or request?
    IIRC I should say i prefer the water pump wh the metal impellor, right? (I'm sure when i spoke to them a while ago, he said they only fit full plastic ones)
    Anything else i should check before booking her in? I know Crasher said to make sure they have the correct tools for the engine etc, but anything else?
    Cheers all
  2. Re: 3.0 v6 petrol cambelt change - quick check
    1840 Post(s)
    I am not fussed by metal impellers, hardly ever see the failure any more. I did the water pump on a 95 Corrado VR6 on Thursday and it was the original pump where the bearings had got upset about going over to G13 after a partial rebuild after 10 years in storage. Odly the pulley was seized on the nose due to rust and I had to put it in the press to get it off and the impeller shattered, then I realised it was plastic but had been perfect so 23 years old and nothing wrong with it. The other day I was looking for a suspension rattle on my Octavia shed and noticed a pink stain from the pump, to my shame/shock I realised it was eight years since I last had one of my trainees change it and that was a genuine pump with plastic impeller.
  3. Re: 3.0 v6 petrol cambelt change - quick check
    Nov 2008
    Leeming
    Could you keep us informed on the price as its no1 job on my list. my problem is that I have bought all the parts including tensioners, water pump and cam locks but i’m too scared to attempt it (even with instructions)
  4. Re: 3.0 v6 petrol cambelt change - quick check
    Liverpool
    11 Post(s)
    blackpool I was quoted either £700 or £750 from a local Audi specialist recently, which isnt bad as i paid £600-ish 6 years ago when it was done. Just remembered a lot of comments about the plastic water pumps giving up, but if Crasher isnt too fussed about it, I'm happy with that. Am away for a week now so will have a ring around next week for prices as have 3 or 4 local specialists to try
  5. Re: 3.0 v6 petrol cambelt change - quick check
    Liverpool
    11 Post(s)
    Quick update all (if anyone finds this while searching the forum). New cambelt, waterpump and tensioners fitted last week, £750. Was having heater issues before it was done, the indy garage told me it was down to the water pump being knackered. Flushed it through and refilled with antifreeze mix.
  1. A4 2093 3.0 v6 petrol cambelt change - competent DIYer?
    By A4B6Cab in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-08-2019, 03:58 PM
  2. Misfire after cambelt change on a4 3.0 petrol ASN
    By arvydasxx in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-06-2015, 06:52 PM
  3. Quick list of things to check on a TDI Passat please :)
    By V6Matt in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-01-2008, 12:04 AM
  4. Cambelt Change - Quick Replies Needed!!!
    By Alun in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-12-2007, 10:55 AM
  5. Opinion on Cambelt change interval for a 1.8T Petrol MK2
    By The Hofmeister in forum Alhambra
    Last Post: 04-10-2007, 12:12 PM
