Thread: The dreaded 2nd gear crunch
Results 1 to 10 of 11
  1. The dreaded 2nd gear crunch
    Jun 2019
    Ez all. My 2006 1.9tdi has started to crunch going from 1st to 2nd 😢 It only happens when the car has been running for a while(30+ min journey) not cold or shorter trips.
    After reading this is a common problem with these boxes what would be my next step? Is its imminent death soon or could it be a change of fluid fix? Obviously it would be silly to get an old box that would just go again? New boxes from a dealer are out of my league. 😢😢😢
  2. Re: The dreaded 2nd gear crunch
    Jun 2010
    London
    mine does it as well. if i slowly go into the 2nd gear then its all good. Bottom line is 2nd gear syncro needs replacing, or second hand gearbox. Dont waste money on fluid changes.
  3. Re: The dreaded 2nd gear crunch
    1840 Post(s)
    Depending on the box series, changing to Red Line MT90 can have an amazing affect on a worn synchro cone, it is something I have been doing and had excellent results from for 30 years, initially with MTL.
  4. Re: The dreaded 2nd gear crunch
    Jun 2019
    Thanks fellas.
    My box is a GQN. How much fluid does it need for replacing? I haven't got the tools for this, so I'd be getting my local mechanic to do this, I'll buy the oil tho.
  5. Re: The dreaded 2nd gear crunch
    Jun 2010
    London
    2.1L for GQN.
  6. Re: The dreaded 2nd gear crunch
    1840 Post(s)
    And don’t laugh because I know it makes no sense, adding gearbox Slick 50 works wonders. A few years ago I had a modified TT from a competitor turn up as he was going nuts trying to stop the 02M crunching into second and he did this using Red Line MT-90 Manual Transmission Synth Gearbox Oil MT | eBay and Slick 50 as he “ had nothing to lose”...... he was incredulous with disbelief when it worked.
    as an interesting aside, Red Line are bringing out a ZDDP additive which could be useful in flat tappet and chain drive cam engines, as long as the oil consumption is very low and by that I mean virtually nil.
  7. Re: The dreaded 2nd gear crunch
    Jun 2010
    London
    Well if it works, why not. I've changed mine 02S with genuine fluid and made no difference. Fluid came out black, like engine oil. My 2nd gear only crunches if i go into it fast.20160904_102913_zpsgmu1hpz2.jpg
  8. Re: The dreaded 2nd gear crunch
    1840 Post(s)
    The only one I remember it spectacularly failing on was an odd one. A customer bought a 10k mile 1993 Golf cabrio about 10 years ago as an investment. Even at this mileage the 020 was crunching into 2nd when cold and we did the usual and it got a lot better. A year or so later he realised it was getting in his way and we brokered it to another customer in Ireland and then did loads of subtle mods to it and it went over there but within a short time 2nd was so bad it had to come back and have the box rebuilt. My rebuild chap said it looked as if the gear was badly made from new as a new cone still sat too tight.
  9. Re: The dreaded 2nd gear crunch
    Jun 2019
    Thanks again fellas 👊
  10. Re: The dreaded 2nd gear crunch
    Jun 2019
    Would it be best to get a VW dealer or specialist to do this? Or would they laugh and suggest a new box/rebuild? Obvs I'll need a few bottles of the Mt 90 and is the slick essential as well?
  1. gear box crunch
    By crashcarter in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-01-2012, 12:22 PM
  2. 2nd Gear crunch
    By Housemaster300 in forum Golf MK3 - 1993 - 1999
    Last Post: 11-09-2009, 09:01 PM
  3. 1st to 2nd Gear Crunch - 07 TSI 140
    By geashton in forum Golf MK5 - 2004 - 2009
    Last Post: 07-01-2009, 11:14 PM
  4. Please Help 3rd Gear Crunch
    By ashab02 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-07-2008, 03:54 PM
  5. Please Help 1st - 2nd gear crunch!
    By theguvnor21 in forum Ibiza - Cordoba
    Last Post: 28-06-2008, 05:23 PM
