Thread: Audi tool # 10060/A ?
Results 1 to 8 of 8
  1. Audi tool # 10060/A ?
    Jan 2016
    Cornwall
    Hi, is Audi tool #10060/A needed on the c6 to take the belt tensioner off
  2. Re: Audi tool # 10060/A ?
    May 2008
    26 Post(s)
    Which belt are you talking about and which engine and year?
    2007 A6 Allroad 3.2 FSI Tiptronic (C6 pre-facelift) - left hand drive
  3. Re: Audi tool # 10060/A ?
    Jan 2016
    Cornwall
    Quote Originally Posted by 54A4Avant View Post
    serpetine belt
    2006 2.0 tdi bre engine code
  4. Re: Audi tool # 10060/A ?
    1841 Post(s)
    It is just a 4.5-mm diameter steel rod.
  5. Re: Audi tool # 10060/A ?
    Feb 2015
    Peterborough
    7 Post(s)
    It’s used to lock the tensioner in the released position. The Sealey kit vse2358 comes with one and the other locking devices you need and is only around £20 so worth buying if you are going to replace the belt.
    2010 A6 TDI 170 S Line Avant
    Sold 2007 A3 TDI 170 S Line
    Sold - 2002 S3
  6. Re: Audi tool # 10060/A ?
    Jan 2016
    Cornwall
    Nice one cheeers
  7. Re: Audi tool # 10060/A ?
    Jan 2016
    Cornwall
    does anyone know how easy it is to access the retaining nut on these tensioners and will I have to remove alternator and / or pas pump to get to it ?
  8. Re: Audi tool # 10060/A ?
    1841 Post(s)
    Bit of a git, deep down inside the bracket from behind and an M10 XZN fine pitch screw normally.
    0 2 0
  1. Question Tool required for Audi Roof Bars
    By i0zjh02 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 30-03-2019, 10:42 AM
  2. Question Audi Diagnostic tool
    By r2sma in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-06-2016, 09:52 AM
  3. Query re EAST VW ScanDi Tool diagnostic tool
    By sarahmac45 in forum VCDS - Help Requests
    Last Post: 15-11-2015, 05:13 PM
  4. mileage correction tool for audi a3 2005
    By 82visionary in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 02-01-2014, 08:33 AM
  5. Audi A6 02 Tool to remove drive shaft?
    By itnoi in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-11-2008, 12:42 PM
