Thread: Audi A3 BKD 2007 non start, flashing brake warning and no ECU communication
Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
  1. Re: Audi A3 BKD 2007 non start, flashing brake warning and no ECU communication
    #21
    1841 Post(s)
    You need to check for ignition live (line 15) at pin 18 of the 94 socket plug (the large one) which ultimately leads back to fuse 2 in the dash side fuse board, I have seen these blow due to faulty brake light switches. You should check for ignition on (line 30a) power to positions 3, 5 and 6 (the larger pins to one side grouped and 1, 2 and 4 are the earths)of the 94 socket plug and if nothing, continuity back to fuse 13 in the engine bay fuse board which comes from the relay terminal 87 on the socket marked 2 on the board.
  2. Re: Audi A3 BKD 2007 non start, flashing brake warning and no ECU communication
    #22
    Jul 2019
    Wadebridge
    Hi, I’ve finally got around to having another go on this -
    Needed to remove the anti tamper screws on the ECU holder
    Can you / have you got any more detail regarding the pins of the ECU plugs ? I know you’ve said the numbers but have you a picture or are there numbers cast into the housing ?
    Really want to get the the bottom of this and really appreciate your help
  3. Re: Audi A3 BKD 2007 non start, flashing brake warning and no ECU communication
    #23
    1841 Post(s)
    There are tiny numbers moulded into the receiving case of the ECU which you have to reverse in your head and look back at the plug to use, or on the reverse of the plug, when stripped down, the numbers are also moulded in but to view any of these I have to use two pairs of glasses and a watch makers magnifying glass, a consequence of getting old. This is why VAG insist on using plug in break out boxes which plug into the cars harness and then into the ECU, giving easy measuring access but these are rare, expensive and difficult to find so we all have the struggle so BEWARE, it is VERY easy to strain and damage the plug pins and they are awful to replace.
  1. Please Help Car won't start, flashing coil warning.
    By mortoney in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-10-2015, 07:45 PM
  2. 2010 Audi S5 Prestige car won't start, brake lights flashing fast
    By whitcom in forum Chat - Anything with wheels
    Last Post: 21-02-2015, 07:06 PM
  3. Replies: 19
    Last Post: 13-01-2015, 09:15 PM
  4. Powerhood warning light flashing on start up
    By jason555 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 08-10-2010, 08:59 AM
  5. asr abs on. brake warning flashing
    By sjcelliot in forum Golf MK4 - 1999 - 2004
    Last Post: 09-12-2008, 05:41 PM
