Thread: Coolant erratic temperature
Results 1 to 10 of 11
  1. Coolant erratic temperature
    May 2019
    Cambs
    My coolant has had an issue over the past few months whereby the gauge is showing fluctuation from 60 degrees up to 90(ish) degrees. It can then can stabilise for a few days like there no problem or continue going up and down. There doesn’t seem to be any trend on how long it takes to go up or down or how long it will stay at that temperature. Sometimes it’s fine for days/weeks and then a few days later it starts again. Doesn’t seem to make any difference on driving style or distance travelled. I’m thinking a faulty thermostat but I’ve also read coolant sensor. Has anyone else experienced this?
  2. Re: Coolant erratic temperature
    1836 Post(s)
    Ignore whatever the gauge says, modern VAG car gauges show an arbitrary figure designed to stop people fretting about minutiae over the readings, if the gauge is moving around and doing odd things, have the sensor replaced and if the issue persists, the thermostat.
  3. Re: Coolant erratic temperature
    May 2019
    Cambs
    Brilliant thanks. There’s only 1 sensor to replace?
  4. Re: Coolant erratic temperature
    1836 Post(s)
    Yes for the gauge, there is another on the radiator but that is for the engine ECU, which year and engine code?
  5. Re: Coolant erratic temperature
    May 2019
    Cambs
    Ok it’s a 2008 239bhp. Not sure on engine code I’ll have to check tonight. Thanks
  6. Re: Coolant erratic temperature
    May 2019
    Cambs
    CAS KMB is that correct?
  7. Re: Coolant erratic temperature
    1836 Post(s)
    CASA engine and a KMB box. Remind me in the morning.
  8. Re: Coolant erratic temperature
    May 2019
    Cambs
    Forgot to remind you
  9. Re: Coolant erratic temperature
    1836 Post(s)
    And I forgot to remember
  10. Re: Coolant erratic temperature
    May 2019
    Cambs
    I’ve remembered this morning
  1. Question Erratic oil and coolant temperature
    By MeDriving in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 17-04-2017, 09:15 PM
  2. Question Loss of coolant and erratic heater temperature
    By Denimblue in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-04-2013, 08:36 PM
  3. Question Engine temperature erratic! 130TDI
    By sherlockuk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-11-2011, 02:19 PM
  4. Erratic Coolant Temperature Gauge
    By cotefarmboy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-07-2011, 05:06 PM
  5. Erratic Temperature gauge?
    By aaronh in forum Golf MK4 - 1999 - 2004
    Last Post: 06-01-2010, 05:49 PM
