Thread: *Another* 2000 Audi a4 B5 1.9 tdi pd limp mode
Results 1 to 10 of 20
  1. *Another* 2000 Audi a4 B5 1.9 tdi pd limp mode
    Jun 2019
    Finistère, France
    Hi guys,
    I have been lurking on these forums for a few years now (yes time flys) trying to solve my problem on my Audi. It will randomly jump into limp mode, at different RPM's , etc. The only thing that is more or less the same every time is that is mostly happens when the weather is pretty hot. The code is p1556.
    So far I have :
    -New turbo
    -New EGR valve
    -All new hoses between actuator, n75, airbox, etc
    -Run tests with VCDS on N75, working great.
    I have a couple logs that might be able to help you guys, Thank you all in advance
  2. Re: *Another* 2000 Audi a4 B5 1.9 tdi pd limp mode
    Jun 2019
    Finistère, France
  3. Re: *Another* 2000 Audi a4 B5 1.9 tdi pd limp mode
    1836 Post(s)
    17964 (P1556) - Charge Pressure Control: Negative Deviation
    This is usually an air leak in the vacuum system. Apply suction to the 3mm vac hose off of the servo to vacuum pump pump, you should not be able to draw any air.
  4. Re: *Another* 2000 Audi a4 B5 1.9 tdi pd limp mode
    Jun 2019
    Finistère, France
    Hi buddy, thank you for the reply, I will check that out, I have renewed all of the hoses, but can't remember seeing that one back there
  5. Re: *Another* 2000 Audi a4 B5 1.9 tdi pd limp mode
    Jun 2019
    Finistère, France
    https://cdn.discordapp.com/attachmen...702_213339.jpg I don't seem to have that vacuum line, and I have a rubber gromet in the firewall where in your picture there is a hose
  6. Re: *Another* 2000 Audi a4 B5 1.9 tdi pd limp mode
    1836 Post(s)
    That thick plastic pipe is the second vacuum feed from the vacuum pump and at some point (usually very close to the pump) must have a one way check valve which has the small vacuum take off moulded in.
  7. Re: *Another* 2000 Audi a4 B5 1.9 tdi pd limp mode
    Jun 2019
    Finistère, France
    https://media.discordapp.net/attachm...901&height=676 This is a bigger picture to make sure im not missleading in any way,
    https://media.discordapp.net/attachm...901&height=676 Would it be this one? The is the only one I can see that seems to be like in your picture? I pulled the bigger hose and was holding vaccum, I pulled the 3mm one off and applied suction but it isnt holding it.
    https://media.discordapp.net/attachm...901&height=676 This is where the 3mm goes to and where I can hear air when applying suction.
    Thank you again for taking the time to help me
  8. Re: *Another* 2000 Audi a4 B5 1.9 tdi pd limp mode
    Jun 2019
    Finistère, France
    https://forums.audipassion.com/appli...57fe0fb0021ddb
    So if I have got it right, I shouldn't be able to draw air / suction at the blue arrow on the one way valve?
  9. Re: *Another* 2000 Audi a4 B5 1.9 tdi pd limp mode
    1836 Post(s)
    From the 3mm vacuum hose that connects to the servo feed pipe, you must not be able to draw any air, you should pull a holding vacuum after a few pumps of a Mityvac type hand pump.
  10. Re: *Another* 2000 Audi a4 B5 1.9 tdi pd limp mode
    Jun 2019
    Finistère, France
    I don't know if you can click the links for the pictures to see if i am in the right place? Can't upload the photos as they are too large... Hopefully we can get this sorted
  1. Please Help Audi A6 C7 2.0 TDI 190 limp mode
    By nathanc31 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 26-11-2018, 02:58 PM
  2. Question 2000 Polo 6KV5 1.4 16v (APE) EML, Limp home mode, the works.
    By Tony S in forum Polo - Derby - Lupo - Fox
    Last Post: 08-09-2015, 06:08 PM
  3. Limp mode / code 17964 on passat tdi 2000
    By zeeeebo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-10-2014, 07:02 PM
  4. Please Help Audi 1.9 Tdi B6 Limp mode
    By Anton98 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-07-2013, 04:12 PM
  5. "Limp Mode" - Audi A4 2002 2.0 Sport in Shoutdown Mode
    By ARJ230580 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-09-2012, 11:14 PM
